Typically it’s best to search the forum to see whether someone already had the same need as yourself
So this would be the results you get with a search for sgp30 https://community.particle.io/search?q=sgp30
And there are two libraries for that sensor (although not particularly the Sparkfun boards) in Web IDE
If you need anything these sources don’t provide you’re welcome to clarify
