I have a custom PCB that only has the setup button (next revision of the board will definitely have both).
I was attempting to see if I could send bad firmware, put the device in an error mode, and then update the firmware over wifi. I should have been using my prototype to test this out instead of my PCB but hindsight…
Is there any way I can force it to safe mode via USB?
I did have a 10 pin JTAG portion added to the board but I’ve never worked with that before… Anyone know what hardware I need to buy in order to use that?
