Hi All,
I sure I’m just having a brain frat, but I can’t seam to work out the speed of an rotary encoder.
What I’m trying to do is when the encoder is turned quickly multiply the change in the encoder by the speed i.e a quick 1/4 turn would equal a fully normal turn or a slow 1/4 would equal a 1/10 turn etc…
I have the encoder setup with external pull-ups, capacitors and get a good clean count on rotation.
I was thinking along the lines of measuring the time between pluses and counting that as pluses/ms, but then I get stuck on converting that to a multiplication factor.
I know this is easy just not thinking straight.
anyways here my code (ino):[code]
void funcEncoderA();
void funcEncoderB();
int _encoderPinA = D2;
int _encoderPinB = D3;
int _encoderValueA = 0;
int _encoderValueB = 0;
int _encoderValueOldA = 0;
int _encoderValueOldB = 0;
volatile bool _encoderLastA = false;
volatile bool _encoderLastB = false;
volatile int _encoderPos = 0;
unsigned long _encoderSpeedA = 0;
unsigned long _encoderSpeedB = 0;
float _encoderPercent;
float _encoderSpeedMultiplier;
unsigned long _lastEncoderTimeA;
unsigned long _lastEncoderTimeB;
int _state = 0;
Time.zone(10.00);
Time.setFormat(TIME_FORMAT_ISO8601_FULL);
Serial.begin(115200);
delay(1000);
Serial.printlnf(Time.timeStr() + “:” + millis() + " - System version: %s", System.version().c_str());
// Pin Modes
pinMode(_encoderPinA, INPUT);
pinMode(_encoderPinB, INPUT);
// Interrupts
attachInterrupt(_encoderPinA, funcEncoderA, CHANGE);
attachInterrupt(_encoderPinB, funcEncoderB, CHANGE);
void funcEncoderA()
_encoderValueA = digitalRead(_encoderPinA);
if(_encoderValueA != _encoderValueOldA)
int s = _state & 3;
if (digitalRead(_encoderPinA)) s |= 4;
if (digitalRead(_encoderPinB)) s |= 8;
switch (s) {
case 0: case 5: case 10: case 15:
break;
case 1: case 7: case 8: case 14:
_encoderPos++; break;
case 2: case 4: case 11: case 13:
_encoderPos–; break;
case 3: case 12:
_encoderPos += 2; break;
default:
_encoderPos -= 2; break;
_state = (s >> 2);
_encoderSpeedA = millis() - _lastEncoderTimeA;
_lastEncoderTimeA = millis();
Serial.printlnf(Time.timeStr() + ":" + millis() + " - A Change - Encoder A: %s, B: %s, Value: %d, Time: " + _encoderSpeedA, _encoderValueA ? "high" : "low", _encoderValueB ? "high" : "low", _encoderPos);
_encoderValueOldA = _encoderValueA;
void funcEncoderB()
_encoderValueB = digitalRead(_encoderPinB);
if( _encoderValueB != _encoderValueOldB )
int s = _state & 3;
switch (s) {
break;
case 3: case 12:
default:
_state = (s >> 2);
_encoderSpeedB = millis() - _lastEncoderTimeB;
_lastEncoderTimeB = millis();
Serial.printlnf(Time.timeStr() + ":" + millis() + " - B Change - Encoder A: %s, B: %s, Value: %d, Time: " + _encoderSpeedB, _encoderValueA ? "high" : "low", _encoderValueB ? "high" : "low", _encoderPos);
_encoderValueOldB = _encoderValueB;
[/code]
and I get an output like Fri Jul 1 10:37:21 2016:5473 - System version: 0.5.1
Fri Jul 1 10:37:24 2016:9315 - B Change - Encoder A: low, B: high, Value: 1, Time: 9315
Fri Jul 1 10:37:24 2016:9319 - A Change - Encoder A: high, B: high, Value: 2, Time: 9319
Fri Jul 1 10:37:24 2016:9326 - B Change - Encoder A: high, B: low, Value: 3, Time: 11
Fri Jul 1 10:37:24 2016:9330 - A Change - Encoder A: low, B: low, Value: 4, Time: 11
Fri Jul 1 10:37:24 2016:9335 - B Change - Encoder A: low, B: high, Value: 5, Time: 9
Fri Jul 1 10:37:24 2016:9339 - A Change - Encoder A: high, B: high, Value: 6, Time: 9
Fri Jul 1 10:37:24 2016:9343 - B Change - Encoder A: high, B: low, Value: 7, Time: 8
Fri Jul 1 10:37:24 2016:9346 - A Change - Encoder A: low, B: low, Value: 8, Time: 7
Fri Jul 1 10:37:24 2016:9351 - B Change - Encoder A: low, B: high, Value: 9, Time: 8
Fri Jul 1 10:37:24 2016:9355 - A Change - Encoder A: high, B: high, Value: 10, Time: 9
Fri Jul 1 10:37:24 2016:9358 - B Change - Encoder A: high, B: low, Value: 11, Time: 7
Fri Jul 1 10:37:24 2016:9362 - A Change - Encoder A: low, B: low, Value: 12, Time: 7
Fri Jul 1 10:37:24 2016:9368 - B Change - Encoder A: low, B: high, Value: 13, Time: 10
Fri Jul 1 10:37:24 2016:9375 - A Change - Encoder A: high, B: high, Value: 14, Time: 13
Fri Jul 1 10:37:24 2016:9380 - B Change - Encoder A: high, B: low, Value: 15, Time: 12
Fri Jul 1 10:37:24 2016:9386 - A Change - Encoder A: low, B: low, Value: 16, Time: 11
Fri Jul 1 10:37:24 2016:9444 - A Change - Encoder A: high, B: low, Value: 15, Time: 58
on a quick 1/4 turn.
Thanks for reading.
