Reading a Rotary Encoder with a Shield Shield using attachInterrupt()
I’m using a rotary encoder from this link and using the Encoder library in the web IDE.
When I attach the A-B pins directly to the Photon’s D2,D3 pins, I can read the encoder via serialPrintln(), albeit not very stable, even though I’m turning it relatively slowly.
When I attach them to pins 11-12 (D2, D3) on the Shield Shield, I get nothing on the serial monitor.
Is the Shield Shied not capable of Interrupts or am doing something wrong?
How does your test code look?
Have you got your pull-up resistors installed?
What value are you using?
With the Shield Shield I’d not rely on the internal pull-ups.
my code is as simple as I can make it.
#include <Adafruit-MotorShield-V2.h>
#include "Encoder.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
Encoder myEnc(D5, D6);
long oldPosition  = -999;
long newPosition = 0;
//bool directionFlag = FALSE;
    AFMS.begin();
    myMotor->setSpeed(255);
    delay(500);
    newPosition = myEnc.read();
    if (newPosition != oldPosition) {
        oldPosition = newPosition;
         Serial.println(newPosition);
   if (newPosition > 10000){ myMotor->run(BACKWARD); }
   if (newPosition < 1){ myMotor->run(FORWARD); }
I have two resistors from A and B phase to the +5v pin on the Shield Shield.
The Motor Shield only uses the two I2C pins. D0-D1 on photon; 5-6 on the Shield Shield.
the Encoder library uses INPUT_PULLUP, so I manually added the Encoder.h file and removed the _PULLUP.
I’ve tried pins D3-D4 and D5-D6, but I still get the same result, which is nothing being printed to the Serial Monitor, unless I hook up the pins directly to the photon.
I'd have to test with my Shield Shield but have no such rotary encoder so I'll try to simulate an open-drain output with one of the other pins.
Still about your pull-ups
Maybe try lowering the value (e.g. 4k7 or 2k2) and maybe measure the voltage on the pins (directly after the pull-up without the encoder and on the Photon)
To simplify the test code even further I'd see what this renders on your setup
#define OPEN_DRAIN
const int intPin = D2;
const int tstPin = D4;  // bridge tstPin to intPin to trigger the interrupt
const int ledPin = D7;
void isr(void) {
  digitalWrite(ledPin, digitalRead(intPin));
  pinMode(intPin, INPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(tstPin, OUTPUT);
  digitalWrite(tstPin, LOW);
  attachInterrupt(intPin, isr, CHANGE);
  static int x = 0;
#if defined(OPEN_DRAIN)
  if (++x & 1) {
    pinMode(tstPin, INPUT); // for Shield Shield external pull-up 4k7/2k2 required
  else {
#else
  digitalWrite(tstPin, ++x & 1);
#endif
  delay(1000);
Update:
On my Shield Shield a 4k7 pull-up to 5V on D2 worked as expected with above code.
Ok, I will give it a try, I had 4.7K on there before, but right now I have 10K installed.
I will give your code a try as well. thanks a bunch for taking the time to try it on your Shield.
