Hi there!
I can’t get a rotary encoder to work using the following code. The code is working OK on arduino.
Any help appreciated.
//------ Encoder Variables
int encoderPinA = D2;
int encoderPinB = D3;
int pushButton = D4;
volatile int lastEncoded = 0;
volatile long encoderValue = 0;
long lastencoderValue = 0;
int lastMSB = 0;
int lastLSB = 0;
//----- OUTPUTS
int led1 = D0;
int led2 = D1;
bool state = HIGH;
// Initialize D0 + D1 pins as output for the two LEDs
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
// Initialize Encoder
pinMode(encoderPinA, INPUT);
pinMode(encoderPinB, INPUT);
pinMode(pushButton, INPUT);
digitalWrite(encoderPinA, HIGH); // turn on pullup resistor
digitalWrite(encoderPinB, HIGH); // turn on pullup resistor
digitalWrite(pushButton, HIGH); // turn pullup resistor on
// attach interrupts
attachInterrupt(encoderPinA, updateEncoder, CHANGE);
attachInterrupt(encoderPinB, updateEncoder, CHANGE);
delay(50);
state = !state;
digitalWrite(led1, state);
Serial.println(encoderValue);
void updateEncoder() {
int MSB = digitalRead(encoderPinA); //MSB = most significant bit
int LSB = digitalRead(encoderPinB); //LSB = least significant bit
int encoded = (MSB << 1) |LSB; //converting the 2 pin value to single number
int sum = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
if (sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderValue ++;
if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderValue --;
lastEncoded = encoded; //store this value for next time
