[RESOLVED] Solid White status LED when running Threads tutorial example
I am trying to run the following example from the Threads Tutorial:
#include "Particle.h"
SYSTEM_THREAD(ENABLED);
void threadFunction(void);
Thread thread("testThread", threadFunction);
volatile int counter = 0;
unsigned long lastReport = 0;
	if (millis() - lastReport >= 1000) {
		lastReport = millis();
		Serial.printlnf("counter=%d", counter);
void threadFunction(void) {
	while(true) {
		counter++;
	// You must not return from the thread function
The device is an LTE E-Series with OS v1.4.0.
I am able to locally compile and flash without any issues. The problem is that the status LED goes to solid white following a reboot or flash. The serial monitor gets stuck at “Polling for available serial device…”
I am able to successfully run applications that do not use Threads without any issues.
UPDATE:
I was able to get it to work by starting the thread after initializing Serial in the setup function.
Thread thread;
    thread = Thread("testThread", threadFunction);
	while(true) {
		counter++;
Thanks! Resolved my problem.
