So…, this happened.
https://dl.dropboxusercontent.com/u/25698542/IMG_1472.JPG
If you can’t see it, the U.FL end snapped right off the GPS board. This happened right before a deadline, so major downer. Antennae kept coming off with minor movement, so I guess I should have glued it down to begin with.
Question is, has anyone had any luck re-soldering these to their board? The exterior leads shouldn’t be a problem, but that middle lead right up against the GPS chip might be an issue.
Better yet, has anyone tried replacing with a stronger connection type?
