Is there a reference for the required, optional, and reserved keys in “loc” events, when customizing firmware based on tracker-edge?
It seems I was unlucky enough to stumble upon “v” at the top level being a reserved field name which prevents “loc-enhanced” events from being generated.
I couldn’t find this documented anywhere though I may have just overlooked it since it’s tricky to search for the single letter “v”.
I don’t see it mentioned in the main event reference Cloud API | Reference Documentation | Particle and the enhanced location reference doesn’t mention it either (despite the fact that it is added to that event) Cloud API | Reference Documentation | Particle
Oddly, including a “src” field in the “loc” event is allowed and gets silently overwritten in “loc-enhanced” whereas a “v” field inhibits “loc-enhanced” altogether.
I’m not sure if this is a bug that “v” inhibits “loc-enhanced” or if it’s intentional and just needs documentation? And what is the meaning of the “v” field that is added to “loc-enhanced” events?
I also submitted two PRs to improve some of the documentation around location and enhanced location events based on the behavior I’ve observed, separate from this issue: Fix 'enhanced_loc' -> 'loc-enhanced', other style improvements by scottbez1 · Pull Request #1175 · particle-iot/docs · GitHub and Fix "loc.src" -> "src" in enhanced location docs by scottbez1 · Pull Request #1176 · particle-iot/docs · GitHub
