My webhook integration is failing roughly 50% of the time and I don’t quite understand why. Hoping someone can see the issue.
I am using a Tracker One with close to default firmware.
The loc-enhanced event is triggering the webhook in this format:
location,equipment={{{PARTICLE_DEVICE_ID}}} lat={{{loc.lat}}},lon={{{loc.lon}}},alt={{{loc.alt}}},temp={{{loc.temp}}} {{{loc.time}}}
When looking at the logs, i noticed loc-enhanced reports in two different formats. It seems the data is different depending on the value of “lck”.
The integration works when the “lck” value is 1 and has the longer data string, but doesn’t work when it is 0 with the shorter data string. Why would this be?
“data”: “{"cmd":"loc","time":1669052942,"loc":{"lck":0,"cell":60,"batt":96.5,"temp":23.2,"time":1669052942,"lat":48.044313,"lon":-71.460554,"h_acc":32},"trig":["imu_m"],"req_id":370,"v":2,"src":["cell","wifi"]}”,
“data”: “{"cmd":"loc","time":1669055203,"loc":{"lck":1,"time":1669055203,"lat":48.044324,"lon":-71.460564,"alt":162.3,"hd":0,"spd":0.06,"h_acc":12,"hdop":10.8,"v_acc":10000000,"vdop":16.6,"cell":60,"batt":96.5,"temp":23},"trig":["lock"],"req_id":372,"v":2,"src":["cell","wifi"]}”,
