Hi.
I’m posing (from my photon) events that incluce sensor id, temp and humidity, and I also have a webhook that posts this to Azure Event Hub. normally this work, but sometimes, especially lately, it appears that particle cloud is transforming the values. I end up with blank [’’] values. I have confirmed this by making my own endpoint and another webhook. All values are sometime [’’].
Has anyone else seen this?
sample:
{"name":"TempRecived","data":"{ \"s\":\"temp\",\"m\":\"TempRH\",\"tempSensorID\":1,\"rhValue\":61,\"tempValue\":11.0\r\nTEMP;2;24;20.5}","ttl":"60","published_at":"2016-05-02T11:44:35.945Z","coreid":"20003b000847343337373738"}
{"name":"hook-sent/TempRecived","data":"undefined","ttl":"60","published_at":"2016-05-02T11:44:35.959Z","coreid":"particle-internal"}
{"name":"hook-sent/TempRecived","data":"undefined","ttl":"60","published_at":"2016-05-02T11:44:35.961Z","coreid":"particle-internal"}
{"name":"hook-response/TempRecived/0","data":"tempsensorID= , rh= , temp = ","ttl":"60","published_at":"2016-05-02T11:44:36.236Z","coreid":"particle-internal"}
