Hi Guys
Need to remove the 227J capacitor from the bottom of the electron due to space restrictions. Will this cause any issues? I have a 220uf capacitor just before the Li+ pin
Ben
Hi Guys
Ben
Particle doesn’t condone the modification of the board, of course. Making changes may require recertification of the Electron, as well.
However, I will point out that a future minor revision of the Electron has two thinner 220 uF capacitors in parallel in the same location next to the SIM slot.
ok, ill take that as a yes it’s fine
