Reliable development board solution that uses cellular and GPS
We want to put sensors to count people on a bus, and we need a web page where we can see the number of people entering and leaving a bus and where the bus is on the map; for that, we need a card. professional development the best one Particle has for a cell phone and GPS, or which one do you recommend?
I recommend looking into the MSoM LTE module that has built-in GPS, but requires hardware design and firmware development. Or for a more off the shelf solution, take a look at the Monitor One device. However, this still might require some custom firmware and hardware design based on your needs.
@jonamleonel besides @ericpietrowicz solid recommendations, you could also consider the new, soon-to-be-released Muon which will work with raspberry pi Hats and will support GPS along with many other features and available enclosures. Though the Muon is a "development" board, I suspect it will be used in products much like the Boron is.
