I just downloaded the Particle parts CAD from github.
There is still no footprint or 3D model for E-series in Altium integrated library.
Are there plans for releasing the footprint and model? I want to use it within 2 weeks.
Makjee,
I have created E-series 3D Model. It doesnt have all the components but has major ones and made to right dimensions so you have an idea.
You can check out the repo.
You can also view it at https://grabcad.com/library/particle-e-series-1
By the way there is Electron step file as well which was taken from the Particle CAD Github libraries and converted from solid works file to step.
Hope this helps.
I am in need of that adjusted eagle library couldnāt find one with a good pin spacing
This is the one Iāve used for 100s of boards, has been working well.
https://github.com/craigdetter/e-series
