Hello, I am having some trouble compiling code that last time I used, worked perfectly. I am using particle Dev and compiling on the cloud. When I click on where the error is it takes me to a blank screen headed with ‘spark_wiring_arduino.h’
The spark_wiring_arduino.h is part of the Particle framework, so these instances need to remain untouched.
But somewhere there must be another occurance which needs to go.
