Red flash connection error
So I decided to have a go at creating a local cloud using this.
I didn’t get it quite working so decided to go back to it at a later date and work on something else.
Problem is now when trying to connect the spark back to the spark servers on the internet I get 3 single red flashes (flashing cyan then 3 red flashes and then a restart, sometimes I get a few green flashes too).
Things I have tried:
All the simple stuff (factory reset, router reset, etc)
Reset the config back to the spark api
Reflashing new firmware
Creating a new set of keys and putting that on the core
Is there an easy fix for this or am I missing something?
You will need to flash the cloud public key as well: https://community.spark.io/t/tutorial-local-cloud-1st-time-instructions-20-march-15/5589
See instructions near the bottom :wink:
Genius! Thank you so much!
