May i read multiple values ( last 10) from a channel field and store them in Photon?
the line reads only the last one value -
float temperatureInF = ThingSpeak.readFloatField(weatherStationChannelNumber, temperatureFieldNumber);
The variable itself is already incapable of storing multiple values, so that’s something worthwhile looking into.
yes …
this is not the right data structure to read multiple values
i could not find any soution using the ThingSpeak library for arduino/photon
my question is more general - is there a solution ?
Yes, I believe what you want to do is possible with webhooks, though I haven’t tried it yet. If you go to ThingSpeak Support->Documentation -> reference->Get a Channel Feed you will see the api for doing it. For instance,
GET https://api.thingspeak.com/channels/9/feeds.json?results=2
gets 2 records (with results=2), you can get up to 8000 according to the docs.
