Background-
This project reads 8 sensors and I originally used the ThingSpeak library and a Photon, worked fine.
I’m starting over to be more bandwidth efficient for an Electron.
I have 8 float variables (CH1 through CH8) containing the Sensor Readings.
I created a webhook from the tutorial Here (GREAT Job btw), and have all 8 ThingSpeak fields updating correctly w/ 1 Decimal Precision via the webhook and 1 Particle.Publish Event every 5 minutes:
EventName & API changed:
Particle.publish("EVENTNAME", "{ \"1\": \"" + String(CH1,1) + "\", \"2\": \"" + String(CH2,1) + "\", \"3\": \"" + String(CH3,1) + "\", \"4\": \"" + String(CH4,1) + "\", \"5\": \"" + String(CH5,1) + "\", \"6\": \"" + String(CH6,1) + "\", \"7\": \"" + String(CH7,1) + "\", \"8\": \"" + String(CH8,1) + "\", \"k\": \"MyAPI\" }", PRIVATE, NO_ACK);
Many of the sensor values don’t change very often and waste data. The reading in CH8 will change and require updating every 5 minutes & should keep the Electron session alive.
I’m looking for a clean way to evaluate each of the 8 Floats (CH1…CH8) vs their previous value, and then build the Particle.publish String with only the fields that require updating.
In my mind, the single Publish Event breaks down like this:
Individual String CONTENTS: Desc:
("EVENTNAME", "{ //Prefix Info for Publish
\"1\": \"" + String(CH1,1) + //Channel 1 String
"\", \"2\": \"" + String(CH2,1) + //Channel 2 String
"\", \"3\": \"" + String(CH3,1) + //Channel 3 String
"\", \"4\": \"" + String(CH4,1) + //Channel 4 String
"\", \"5\": \"" + String(CH5,2) + //Channel 5 String
"\", \"6\": \"" + String(CH6,1) + //Channel 6 String
"\", \"7\": \"" + String(CH7,2) + //Channel 7 String
"\", \"8\": \"" + String(CH8,2) + //Channel 8 String
"\", \"k\": \"MyAPI\" }", PRIVATE, NO_ACK) //Suffix Info for Publish
From my research, this looks like a job for a String Array, but I’m getting nowhere.
All help, suggestions, and comments are greatly appreciated.
Thanks in Advance !
