I would like to remotely read the WiFi SSID that my Photon is connected to.
I am able to read the RSSI using a “Particle.function” and WiFi.RSSI, I would like to do the same for the WiFi.SSID.
I read the Particle.function on the Particle App, Device Inspector, Data screen.
This is what I found in the Particle docs: " WiFi.SSID() returns the SSID of the network the device is currently connected to as a char* ."
I have tried the following, based on my success with the WiFi.RSSI() function:
Particle.function("SSID", SSID);
truncated other lines...
char* SSID()
SSID = WiFi.SSID();
return WiFi.SSID();
It appears I am violating the formatting of the "char* ".
Any thoughts would be greatly appreciated.
Image of the Particle App with RSSI:
