Hello!
I am currently using the JsonParserGeneratorRK library to send data to the cloud in the form of JSON packages. I want to store a battery voltage over a period of time and then send that to the cloud. For example, a timer in the Main() loop stores the batt value every 10 minutes. Each value is stored as a key in a JSON object (using the library). After the 10th key has populated the object, the oldest key is deleted and the newest key is added. My goal is to keep the JSON Object into a manageable size for to use over Cellular network.
This is an interesting use case. While you can do it with the existing library, I created version 0.1.3 with four new methods to make this easier.
Added JsonWriter methods insertKeyArray() and insertKeyVector() to make it easier to add arrays.
Added JsonWriter methods insertArray() and insertVector() to make it easier to add arrays.
The assumption here is that you’ll have an object that conceptually looks like:
"a":"test",
"b":[
100.00,
99.99,
99.90
Where “a” is could be any number of keys with any kind of data.
The “b” key is an array of floats. If you wanted to record both a timestamp and a value “b” would need to be an object instead which would be a little more complicated, but still possible.
You’d store your array of float (battery SoC) as a global variable like:
std::vector<float> batteryCharge;
And when you add an element every 10 minutes, you’d do something like:
batteryCharge.push_back(System.batteryCharge();
if (batteryCharge.size() > 10) {
// Remove the first (oldest) element
batteryCharge.erase(batteryCharge.begin());
