Pushing data from ubidots to photon
My goal is to be able to send a few parameters from ubidots slide control to my photon.
I have not found any references showing how to do that.
Does anyone have any code examples that shows it?
further are there any advantages to using mqtt over http? I don’t understand all this
thanks steve
That might be something @mariahernandez could answer maybe.
Hello @murmsk,
In the example folder of the Ubidots Library you will find a getValue example, this example will serves you to obtain the last value from a Ubidots variable. For any additional question you can reference to the Ubidots Help Center.
All the best,
Maria C.
@murmsk In addition to what Maria said, I was able to get this to work using Webhooks as I do not use the Ubidots library.
More detail here.
Thanks, Chip
