Hello! I currently have an Electron 2G set up to publish data every 18 minutes and between publishes enter stop mode with SLEEP_NETWORK_STANDBY so the connection is preserved. However since the connection to the cloud never resets the Electron never sends a new “spark/device/diagnostics/update” event.
Is there any way to force this event being published from the firmware without creating a completely new connection that takes a lot of data? Or can I get the variables from the diagnostics event by themselves?
I’m primarily interested in
- Battery percentage
- Battery voltage
- Memory used and total
- Signal strength (%)
- Signal strength (dB)
- Round-trip time
At least battery percentage and voltage I know that I can get from function calls in the firmware.
EDIT: After checking the docs more thoroughly I found what I needed. Instead of publishing vitals at command however I will only publish the data I’m interested in, to save data
