I want to publish an event with a PHP ?
Is it possible ?
Searching the forum turned up this:
A little old, but it should be a good starting point.
Thanks but this is for Particle.function()
I need to publish event
I think the code above can get you started.
You would need to know what is the curl command for an event, and you can get that here.
Cheers!
