I have been trying to use the cloud API, i have followed the documentations and got the header to work, but when whole trying to do the body, I have been having trouble with it.
This is what i have been trying to follow
This method worked for me while using curl on terminal, but not im trying to attempt the same thing using php.
$ curl https://api.particle.io/v1/devices/events \
-d "name=myevent" \
-d "data=Hello World" \
-d "private=true" \
-d "ttl=60" \
-d "access_token=1234"
This is my code on php
<?php
$header = array(
"Authorization:Bearer xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
$body = array(
"name: turnpm",
"data: led-on",
"private: false",
"access_token: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
$ch= curl_init();
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_POST, TRUE);
curl_setopt($ch, CURLOPT_POSTFIELDS, http_build_query($body));
curl_setopt($ch, CURLOPT_HTTPHEADER, $header);
$output = curl_exec($ch);
echo $output;
curl_close($ch);
This is my particle code
Particle.subscribe("turnpm", myHandler);
void myHandler(const char *event, const char *data)
########## code ###########
The result that i get from all that
{"ok":false,"error":"event name is required"}
I’m suspecting the body not being sent correctly. The name, or the data arent being found within the API. i’m not sure what to do at this point I have checked my syntax in the php and everything seems to be in order. help would be really appreciated.
UPDATE:
Fixed with changing
curl_setopt($ch, CURLOPT_POSTFIELDS, $body);
to
curl_setopt($ch, CURLOPT_POSTFIELDS, "name=turnpm&data=led-off&....");
