Hi @jonamleonel -
Your project sounds interesting indeed. Without having all the information I would think the following should be what you would want to look at:
- Particle Boron or B523
- These sensors from Figaro seems quite good, but again, I don’t have all the info.
- Voltaic solar panels are quite good and suitable for outdoor use. In used them in a previous project of mine.
With regards to the enclosure, if it was me, I would design a custom one. By the sound of it you will be doing a couple at least, so I would think it is worth the investment.
With regards to the PSU… I would go wit solar backed up by at last 2800mAh Lipo. I will also include the option to use permanent power where available. To do this, I use RECOM encapsulated PSU as you can see in this project.
It would be interesting to know what you are going to use as user interface?
Hope this helps.
Friedl.
