Dear forum,
I have just installed the new firmware in my photon and I have a problem with a specific function my program.
I was using a webhook to write data to a MySQL database . My webhook file is
"event": "blabla",
"url": "http://www.xxxxxx.com/insert.php",
"requestType": "POST",
"form": {
"data": "{{SPARK_EVENT_VALUE}}",
"published_at": "{{SPARK_PUBLISHED_AT}}",
"coreid": "{{SPARK_CORE_ID}}"
"mydevices": true
My code for calling this event is
Particle.publish("blabla", publish_buffer, 60, PRIVATE);
Is this happenned to anyone else ? When I had the 0.4.7 everything was working very nice.
Any solution to that?
Kind Regards
John
Ric
February 11, 2016, 8:33pm
#2
Is what happening to anyone else? You haven’t said what’s wrong.
Hi , yes sorry.
The photon is working OK but it does not publish any data.
the webhook is not working at all.
any suggestions?
@johnyrobot5 , are you seeing the publish event in the dashboard? When did you initially create the webhook? Do you have the latest version of the CLI?
Hi peekay,
Yes I can see the event in the dashboard . But why is not writing to the MySQL?
I do not understand.
Yes, I gave the latest CLI
@johnyrobot5 , do you see the webhook response in the dashboard as well?
This is what I see in the dasboard.
I hope that helps.
I have also gone to MySQL logs in the server and no POST methods are logged , That might seem that the webhook for some reason does not POST to the PHP file in the server.
OK I have found where was the problem and SOLVED it
The webhook I had created in the past was not working. I created a new webhook and everything worked fine .
Thank you for your answers
