Particle to Webhook to PHP to MariaDB MySQL
This is the code to send from the Particle to the Webhook:
// This is the string to be published.
String data = String(PM25);
// This is the column that the string is published in.
Particle.publish(“Atmovision01a-to-PHP”, data);
The webhook is built like this:
The PHP looks like this:
I can not get my PHP script to display correctly in text and I can only post 2 images. My PHP script is in the reply below.
When I hit the “TEST” button while viewing my Webhook Integration, this happens in my database:
Unfortunately, nothing else posts in my database from the particle when it’s running… I plan to do SSL/etc. after I get this working. Does anyone know how to fix this?
What do you see in console.particle.io/logs when you send the event?
You should also use PRIVATE for your publish call.
But the most important is that you have a case issue.
Once you are using a capital V while the published event uses a lower case v
I don’t want to talk about how many things or how long I tried to troubleshoot without noticing the case issue. Thank you so much, everything works now!
