Hi all,
I am trying to write a program to acquire the samples of the signal at at least 200Hz and send the data to my laptop using the TCP server. The problem is that whenever I achieve the connection between my laptop and spark, after maybe 2-3 seconds, the spark starts flashing red and reboots itself.
The problem doesn’t seem to appear if I change the interrupt from 3ms to 10ms. However, that is too slow for me.
I would really appreciate any help. I also include the whole code I have written, as maybe there is something wrong with my approach and you are able to find it.
Thanks for your time!
// Libraries
#include "application.h"
#include "SHT1x.h"
#include "SparkIntervalTimer/SparkIntervalTimer.h"
#include "sd-card-library/sd-card-library.h"
#include "spark_disable_wlan.h"
#include "spark_disable_cloud.h"
// Wifi Defines
//WiFi_Status_TypeDef last_wifi_status;
TCPServer server = TCPServer(80);
TCPClient client;
// Constants
const uint8_t chipSelect = A2; // Also used for HARDWARE SPI setup
const uint8_t mosiPin = A5;
const uint8_t misoPin = A4;
const uint8_t clockPin_2 = A3;
const int Zout = A6;
const int Xout = A7;
const int Yout = A1;
const int testPin = D5;
// Test
int ledState = LOW;
volatile unsigned long blinkCount = 0; // use volatile for shared variables
//Delay timer to create a non-delay() x-second sampling timer
unsigned long wait = millis();
const unsigned long waittime = 5000L;
// Specify data and clock connections and instantiate SHT1x object
#define dataPin D0
#define clockPin D1
SHT1x sht1x(dataPin, clockPin);
// ECG variables
int ecgPin = A0;
int z = 0;
int l = 1;
int ecgReading[2][500] = {{0},{0}};
int counter = 0;
int counter_temp = 0;
int counter_acc = 0;
IntervalTimer myTimer;
// Accelerometer variables
int Xout_read;
int Yout_read;
int Zout_read;
// SD card
File ecgFile;
File tempFile;
File accFile;
//last_wifi_status = WiFi.ready();
//WiFi.ready();
WiFi.on();
//Serial.println(WiFi.localIP());
server.begin();
//Serial.begin(9600);
SD.begin(mosiPin, misoPin, clockPin_2, chipSelect);
pinMode(testPin, OUTPUT);
myTimer.begin(getEcg, 3000, uSec); // collect ecgData every 3mili seconds
void getEcg(){
ecgReading[z][counter] = analogRead(ecgPin);
counter = counter +1;
if (ledState == LOW) {
ledState = HIGH;
} else {
ledState = LOW;
digitalWrite(testPin, ledState);
void saveECG(){
l = 1 - z;
ecgFile = SD.open("ECG.txt", FILE_WRITE);
if (ecgFile) {
//Serial.println("Starts saving ECG");
for(int i = 0; i<500; i++){
server.println(ecgReading[l][i]);
ecgFile.print(ecgReading[l][i]);
ecgFile.print(";");
ecgFile.close();
//Serial.println("Finished saving ECG");
} else {
// if the file didn't open, print an error:
//Serial.println("error opening ECG file");
void getAcc(){
Xout_read = analogRead(Xout);
Yout_read = analogRead(Yout);
Zout_read = analogRead(Zout);
// Print the values to the SD card
accFile = SD.open("Acc.txt", FILE_WRITE);
if (accFile) {
//Serial.println("Starts saving acc");
accFile.print("X = ");
accFile.print(Xout_read);
accFile.print(" Y = ");
accFile.print(Yout_read);
accFile.print(" Z = ");
accFile.println(Zout_read);
server.print("X = ");
server.print(Xout_read);
server.print(" Y = ");
server.print(Yout_read);
server.print(" Z = ");
server.println(Zout_read);
accFile.close();
//Serial.println("Finished saving acc");
} else {
//Serial.println("error opening Acc file");
void getTemp(){
float temp_c;
//float temp_f;
float humidity;
if (millis() > wait) {
wait = millis() + waittime;
// Read values from the sensor
temp_c = sht1x.readTemperatureC();
humidity = sht1x.readHumidity();
tempFile = SD.open("Temp.txt", FILE_WRITE);
if (tempFile) {
//Serial.println("Starts saving temp");
tempFile.print(temp_c, DEC);
tempFile.print("C ");
tempFile.print(humidity);
tempFile.println("%");
// Print the values to the serial port
//server.print("Temperature: ");
server.print(temp_c, DEC);
server.print("C ");
server.print(humidity);
server.println("%");
tempFile.close();
//Serial.println("Finished saving temp");
} else {
//Serial.println("error opening Temp file");
if (counter >= 500){
noInterrupts();
z = 1 - z;
counter = 0;
interrupts();
counter_acc = counter_acc +1;
saveECG();
if (counter_acc >= 12){
counter_temp = counter_temp +1;
counter_acc = 0;
getAcc();
if (counter_temp >=2){
getTemp();
counter_temp = 0;
if (!client.connected()){
// if no client is yet connected, check for a new connection
client = server.available();
