Hi all,
Currently working on a project with a TCP Server and could use some help. The reliability of the core’s connections are very iffy right now and I could use some help from experts… Below is my python code
#buf is our output file
spark_core = '10.0.0.7'
sc_port = 17061
BUFFER_SIZE = 2048
#just about the right amount of time to wait in between sending
perfect_time = 0.015
#print buf
print "Trying to socket and connect"
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
for x in xrange(2):
try:
s.connect((spark_core, sc_port))
print "connected"
for x in buf:
s.send(x)
time.sleep(perfect_time)
print "Done sending"
s.close()
break
except:
print "Failure"
Here is a pastebin of my Core code: http://pastebin.com/YYw0kzct
The output I get is usually like:
updating
connected
Done sending
updating
connected
Done sending
updating
… (anywhere from 10 seconds to 5 minutes later) …
Failure
Failure
updating
Failure
Failure
updating
Failure
Failure
…(continues in this fashion, and most of the time results in the Core rebooting)…
Edit: When the core does reboot, it usually takes a few attempts to actually get a connection again.
Forgot to mention, I am also having trouble flashing after a connection has already been made to the device. I have to turn it off and on again then try to reflash.
