Hi all,
I have tried to make some print statements to the WEB IDE - but how does this work? Is there a terminal somewhere or do the web IDE takes a special print statement?
Hope someone can help me with this!
Hi all,
There are several options including the Particle CLI. There isn't a way to display it in the Web IDE.
You can find a number of options in USB serial debugging.
Thank you for your reply.
Initially I found it confusing because I was using the Particle CLI to type commands etc and it was here I got these errors.
But I found that if I used the "split terminal" option it opens an Powershell window and in this new window I could use the "Particle serial monitor --follow" command without any errors.
