Precise Timing options
Hello,
I was wondering if the GNSS receiver on the Tachyon allows to route a 1 PPS signal or similar to one of the header pins? For my application I need a sub microsecond timing accurate synchronization signal and was hoping I could use the inbuilt GNSS receiver for that, otherwise I may have to add an additional GNSS module, which I’d like to avoid.
Thanks a lot!
Thanks for asking, @niklasc!
The QCM6490 on the Tachyon supports GNSS (GPS, GLONASS, etc.), but it doesn’t provide a PPS (pulse-per-second) output directly. That functionality typically comes from a separate GNSS module, so if you’re looking to use PPS for time sync (like with NTP or Chrony), you’ll need to connect a GNSS module that exposes a PPS signal on a GPIO.
We do synchronize time from cellular networks, but also don’t have a precise ms accurate time stamp sadly.
Since you’re using Tachyon, which is Raspberry Pi compatible, you can easily add one of the Raspberry Pi HATs that provide PPS:
1. Adafruit Ultimate GPS HAT
  • Based on a u-blox GPS chip
  • PPS on GPIO 4 by default
  • Works with gpsd and ntp or Chrony
  • Well-documented and reliable - we use their modules in our own products!
2. Waveshare MAX-M8Q GNSS HAT
  • Also uses a u-blox chip
  • Exposes PPS via a header
  • Compatible with standard Linux PPS tools
Both are low-cost and known to work well with Pi-style boards like Tachyon.
Hope that helps!
Nick
This blog describes the implementation of an NTP server on a Raspberry Pi. What is needed for NTP is precise timing. The author is using a Uputronics GPS hat.
Raspberry Pi NTP Server - Part 1
