Tachyon_GNSS Satellite Fix
Hello,
Merry Christmas!
Could someone advise on how to get GPS signal for the Tachyon? I used the command particle-tachyon-ril-ctl gnss and the output is all zeroes. The antenna is by the window. It has been about 30-minutes. Is there anything else I need to do?
Thank you for your time.
I have a satellite fix now.
Hey barbbq, yeah Merry Christmas all :christmas_tree:
You must be using 20.04 because it's all changed with 24.04, which doesn't work yet as of 1.1.32 as per docs and not sure about 1.1.33. :face_with_diagonal_mouth:
Does anyone know where the changelog is for these builds, even a comment about GNNS working etc. would be helpful?
I have a rather cool cpp app that displays battery and GPS data every 30s if you'd like?
@Perky Release notes for 1.1.32: https://drive.google.com/file/d/1jKuWQf75zsvQP-mLYwVkDqth-hrCX466/view
Thanks Bauer, I was after the 1.1.33 version which is now available for download :slight_smile:
