Prebuild Binaries Location (0.50)? [SOLVED]
Hi
Good to see the 0.50 release is available as a beta build. I do not have a build environment set up, are there the usual two photon .bin fles located somewhere? Also - is there a command to see what build a device is currently running?
Thank you
Kevin
There
To find out what system your device has currently got installed you can put it into Listening/Setup Mode (blinking blue) and perform
particle serial identify
Thanks for the prompt response. I have found that page, but still cannot locate, e.g. system-part1-0.5.0-rc.1-photon.bin
You’ll have to scroll quite a bit down on that page (right down to the bottom)
