Powering sensors
Hi everyone. I got a question. I am using Electron in my project with a couple sensors and a solar panel to charge the battery. I want add a rain gauge sensor which has to be power while the device is in sleep mode. I don’t think it is possible to power the rain gauge directly from Electron while it is in sleep mode.
But I want to ask anyway if this is possible?
Have you had a look at the Electron datasheet (i.e. 3v3 pin) :wink:
Thank you for pointing that out. I was working with Boron before and I didn’t see that on Boron datasheet. Beginner’s mistakes
But it's there too
https://docs.particle.io/datasheets/cellular/boron-datasheet/#3v3-pin
By default the 3v3 pin will source current. On the Boron (and Argon/Xenon) the step-down regulator can be powered down by externally by pulling EN pin low.
I guess I didn’t understand what that meant because I am a super noob. Thank you though.
Hi @phisuthisakn
Which sensor are you referring to exactly? Did you have a look at the power requirement of the sensor itself?
Friedl
I did look at the power requirement. Thank you for trying to help.
Did you manage to resolve this?
Regards Friedl.
Yes I did.
Thank you,
Phisuthisak Ngernkuakul
From my thoughts, it is possible to power the rain gauge directly from Electron when it is in sleep mode.
