Powering BME280
Hi :slight_smile:
Which pins can I use to power up a sensor like the BME280? Currently I’m powering the sensor throughthe 3v3 pin but I want to turn off the sensorso that is why I want to use a pin which I can programm.
You may want to state which host device you are thinking of using too.
However, we encourage people to search the forum for possible parallel questions before asking the same or a similar question.
Please read the forum guidelines (especially Step 2)
https://community.particle.io/t/welcome-using-particle-forums-and-forum-etiquette
A simple search for "power BME280" could have turned up this thread
You may find your answer in there (or one of the other threads returned by this search).
If you then can't get to your answer you are welcome to specify what else you need.
