I am making a custom P1 Module based board.I will be powering the board though 5V 1A DC supply adapter (Because i also have 5v Relay on the board) I was planning to use AMS1117 3.3V Power Supply to Power the P1 Module.
I had some doubts Regarding the Voltage Regulator
Is T
(Note:There is a small error in the schematic the output is 3.3V)
I searched the net and got this schematic for the Power Supply.Is this Voltage Regulator Good enough to Power the P1 module or shall i use some other Voltage Regulator?
Is the Schematic As in the Image and Capacitor Values and type Correct or I should Make some Changes to It?
