I am preparing to try Adafruit_BLE - Port of Adafruit_BluefruitLE_nRF51 in a Photon particle using informations from https://github.com/rickkas7/Adafruit_BLE. I would like to know if I just need include my original code inside the code from the link.
The files in the src folder are what we commonly call the library files which you - in most cases don’t want to change - and the files inside the examples folder are … well … examples.
You can take the example files and add your code, or just have a look at these samples to understand how the library is meant to be used and then build your own code applying the gathered insight.
