On a 0.6.3 Photon, in the Web IDE after doing
#include <Adafruit_CCS811.h>
(using the bookmark tab in the IDE to include it) I get an error:
bme280test.ino:15:29: Adafruit_CCS811.h: No such file or directory
Full code here:
#include <SparkFunMicroOLED.h>
// Code from:
// https://community.particle.io/t/bme280-reading-problem/34642/7
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
/* MicroOLED ------------- Photon
GND ------------------- GND
VDD ------------------- 3.3V (VCC)
D1/MOSI ----------------- A5 (don't change)
D0/SCK ------------------ A3 (don't change)
D2
D/C ------------------- D6 (can be any digital pin)
RST ------------------- D7 (can be any digital pin)
CS ------------------- A2 (can be any digital pin)
Adafruit_BME280 bme;
MicroOLED oled;
#define BME_MOSI D0
#define BME_SCK D1
#define SEALEVELPRESSURE_HPA (1013.25)
// setup() runs once, when the device is first turned on.
oled.begin(); // Initialize the OLED
oled.clear(ALL); // Clear the display's internal memory
oled.display(); // Display what's in the buffer (splashscreen)
delay(1000); // Delay 1000 ms
oled.clear(PAGE); // Clear the buffer.
// randomSeed(analogRead(A0) + analogRead(A1));
oled.setFontType(1); // Set font to type 1 (display can show 3 lines of 7 chars.)
oled.clear(PAGE); // Clear the page
oled.setCursor(0, 0); // Set cursor to top-left (x,y)
// Print can be used to print a string to the screen:
oled.print("OLED OK");
oled.display();
if (bme.begin()) // had arg = 0x76
Particle.publish("BME280 sensor works!",PRIVATE);
oled.setCursor(0, 16);
oled.print ("BME OK");
oled.display();
delay (1000) ;
// loop() runs over and over again, as quickly as it can execute.
// The core of your code will likely live here.
float t = bme.readTemperature() * 9 / 5 + 32 ; // *F
float h = bme.readHumidity(); // %
float p = bme.readPressure() / 100.0F; // hPa
float a = bme.readAltitude(SEALEVELPRESSURE_HPA);
// Get some data - measure battery voltage
String data = String::format("%.2f",t) + "*C:" + String::format("%.2f",h) + "%:"
+ String::format("%.2f",p) + "hPa:" + String::format("%.2f",a) + "m";
// Publish data to Particle Cloud
// Particle.publish("data", data,PRIVATE);
oled.clear(PAGE) ;
oled.setCursor(0, 16); // Set cursor to top-left (x,y)
oled.print ("T=") ;
oled.print (t) ;
oled.setCursor(0, 32);
oled.print ("H=") ;
oled.print (h) ;
oled.display();
delay(1000);
I have seen this problem before and it seems to be a glitch in the Web IDE (with several other libraries too).
For me just changing #include <Adafruit_CCS811.h> to #include "Adafruit_CCS811.h" usually cures the problem. Once you have changed that, you can even change it back and the build still works.
It might be, that the omitted “stub-header” ./Adafruit_CCS811/Adafruit_CCS811.h may cause that behaviour in Web IDE, but having it there usually created other issues with Particle Dev Desktop IDE and CLI, so I decided to not include it (and it’s not used in Arduino libraries either).
Well this is very odd. If I create a new app with nothing other than
in it, it compiles just fine. But when I try that line in the code I posted in the OP, it still gives that NSF error. I tried removing the original CCS811 library using the “X” button in the IDE and then reincluding it using the bookmark icon and changing the name from <> to “”, but it still won’t find it.
Just out of curiosity, are you able to get the program I posted to compile with the library in quotes?
Because if you look at what the compiler/linker is actually doing, it’s like it doesn’t even see that include line. (Note there’s no entry for “Checking library Adafruit_CCS811.h”)
Processing bme280test.ino
Checking library Adafruit_BME280...
Checking library Adafruit_Sensor...
Checking library SparkFunMicroOLED...
Installing library Adafruit_Sensor 1.0.2 to lib/Adafruit_Sensor ...
Installing library Adafruit_BME280 1.1.4 to lib/Adafruit_BME280 ...
Installing library SparkFunMicroOLED 1.3.0 to lib/SparkFunMicroOLED ...
Library Adafruit_BME280 1.1.4 installed.
Library SparkFunMicroOLED 1.3.0 installed.
Library Adafruit_Sensor 1.0.2 installed.
make -C ../modules/photon/user-part all
make[1]: Entering directory '/firmware/modules/photon/user-part'
make -C ../../../user
make[2]: Entering directory '/firmware/user'
Building cpp file: src/bme280test.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-6-msrc/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFORM_NAME=photon -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=6 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DPARTICLE_NO_ARDUINO_COMPATIBILITY=0 -DSYSTEM_VERSION_STRING=0.6.1 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../communication/src -I../hal/inc -I../hal/shared -I../hal/src/photon -I../hal/src/stm32f2xx -I../hal/src/stm32 -I../hal/src/photon/api -I../platform/shared/inc -I../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../dynalib/inc -Isrc -I./libraries -Isrc -Isrc -Isrc -Isrc -Ilib/Adafruit_Sensor/src -Ilib/SparkFunMicroOLED/src -Ilib/Adafruit_BME280/src -I. -MD -MP -MF ../build/target/user/platform-6-msrc/bme280test.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=BCM9WCDUSI09 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSE_THREADING=0 -DUSE_SPI=SPI -DUSE_CS=A2 -DUSE_SPI=SPI -DUSE_CS=A2 -DUSE_THREADING=0 -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=4 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,105 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\"" -fno-exceptions -fno-rtti -fcheck-new -std=gnu++11 -c -o ../build/target/user/platform-6-msrc/bme280test.o src/bme280test.cpp
bme280test.ino:2:29: fatal error: Adafruit_CCS811.h: No such file or directory
compilation terminated.
../build/module.mk:267: recipe for target '../build/target/user/platform-6-msrc/bme280test.o' failed
make[2]: Leaving directory '/firmware/user'
make[2]: *** [../build/target/user/platform-6-msrc/bme280test.o] Error 1
../../../build/recurse.mk:11: recipe for target 'user' failed
make[1]: *** [user] Error 2
make[1]: Leaving directory '/firmware/modules/photon/user-part'
../build/recurse.mk:11: recipe for target 'modules/photon/user-part' failed
make: *** [modules/photon/user-part] Error 2
UPDATE: I tried copying the body of the non-compiling code from the OP into the blank app that did work and compiling that. Now that works. Go figure.
Anyway, thanks @ScruffR. You had the answer, as always.
Oh and for the benefit of anyone else trying to get this sensor running, there are a number of contradictory examples out there. I found that I had to start the sensor with the line
ccs.begin(0x5B)
or it wouldn’t work. (0x5B is the default I2C address for the CCS811 on the Sparkfun CCS811+BME280 combo board I’m using).
