Hi Team,
I am using a photon connected to your programmer shield.
I got them recognised as BCM943362WCD4 board.
I run the wiced sdk example and I dont have access to the wifi.
Here are the results with the snip.scan example from broadcom:
Starting WICED v3.5.2
Platform BCM943362WCD4 initialised
Started ThreadX v5.6
Initialising NetX_Duo v5.7_sp2
Creating Packet pools
Waiting for scan results…
Type BSSID RSSI Rate Chan Security SSID
Would you have a profile or a patch to applied to the wiced sdk to get your board / programer shield recognised correctly ?
Thank you
