Photon unable to be flashed over USB
I have a Photon that I need to flash over a USB connection using a MAC.
Now with the LED flashing YELLOW. I do the dfu-util command and get:
$ dfu-util -l
dfu-util 0.7
Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2012 Tormod Volden and Stefan Schmidt
Found DFU: [2b04:d006] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/03016Ka,01016Kg,01064Kg,07128Kg"**
Found DFU: [2b04:d006] devnum=0, cfg=1, intf=0, alt=1, name="@DCT Flash /0x00000000/01016Kg"*
So all seems well…
Next I try to flash over usb
$ particle flash usb photon_firmware_1486312357348.bin
Including:
attempting to flash firmware to your device usb
Flash device failed
I didn’t recognize that device name or ID, try opening https://api.particle.io/v1/devices?access_token=`my_secert_ptr_to_api_tokens_etc
Now when I open this link up I see the device its Device ID is correct.
So what do I do to get the particle command line to flash over usb again?
I have to go this route as the program has a WiFi setup wrong so the Photon cannot be flashed via cloud.
ChipMonk
HI All,
Was a simple command line error.
the flash command should have been…
particle flash -usb photon_firmware_148631235677.bin
Another case of cockpit error.
Chipmonk
I think you still have an error - at least in this post.
You need two dashes for --usb
Hi ScruffR,
Yes you are correct the command is
particle flash --usb <photon.bin>
ChipMonk
