As mentioned here (although I'm not from Particle)
Although I didn't have such a problem with the original Particle Power Shield. @frlobo, have you got a link to a thread where an original Particle Power Shield did cause this behaviour?
In this case there'd need to be an issue opened on the shield hardware repo too.
I don't have a battery shield from particle... Only a power/battery shield from SparkFun.
This issue will not happen if you use the battery shield alone, since when the battery is dry you connect it to USB and it will be enough power to charge and power the photon....
It will most likely happen if you use it with a solar panel. Because once the battery is dry it will die.. But when the solar power kicks in.. There is a time where it will be attempting to power the photon and charge the battery. I am guessing this is the moment where the issues occur... Right when the battery gets sufficient power to attempt a boot but when the photon boots it drains the battery quickly and thus the cycle continues for a while....
AGAIN. newbie here... Just making conclusions that might be way off road.
This might be something for SparkFun to look into but maybe @BDub can also comment here (and more importantly in the GitHub issue for safe keeping and ease of reference)
It would be useful if the controler on the shield would only allow a power-up if the battery got beyond a certain level of charge that will allow the device to properly work at least for a few minutes.
I’m quite sure there is a hysteresis set, but it might need to be increased and since the controler can’t know your external circuitry, which might outweigh the Particles own power consumption and hence render the set hysteresis too small again, it might also be useful to allow for the user to twiddle that setting to fit the hardware setup (with documentation ;-))
oops, meant this to appear below “MDMA’s” post of 1 June. Guess I need know just a teetee more about the thread system…
running “particle keys new” got the following response:
‘openssl’ is not recognized as an internal or external command
–On further investigation–
evidently I have to load a bunch of other stuff…what is the total package required to talk use ‘Particle’ commands effectively?
Flashing Cyan / Red - still not resolved. Cannot connect this sucker.
Device has been claimed
It’s connected before and has worked - then stopped
Tried all suggestions in this thread and then tried running the key doctor while in DFU mode:
particle keys doctor 3D0020000347343339373536
and I get this error:
Error sending public key to server: Permission Denied
Anything else to try?
Full text here:
running dfu-util -l
Found DFU device 2b04:d006
running dfu-util -l
running openssl genrsa -out 3D0020000347343339373536_rsa_new.pem 1024
running openssl rsa -in 3D0020000347343339373536_rsa_new.pem -pubout -out 3D0020000347343339373536_rsa_new.pub.pem
running openssl rsa -in 3D0020000347343339373536_rsa_new.pem -outform DER -out 3D0020000347343339373536_rsa_new.der
New Key Created!
running dfu-util -l
This file already exists, please specify a different file, or use the --force flag.
Continuing…
checking file 3D0020000347343339373536_rsa_new.der
spawning dfu-util -d 2b04:d006 -a 1 -i 0 -s 34:leave -D 3D0020000347343339373536_rsa_new.der
dfu-util 0.8
Deducing device DFU version from functional descriptor length
Opening DFU capable USB device…
ID 2b04:d006
Claiming USB DFU Interface…
Setting Alternate Setting #1 …
dfuIDLE, continuing
DfuSe interface name: "DCT Flash "
Downloading to address = 0x00000022, size = 610
Download [=========================] 100% 610 bytes
Download done.
File downloaded successfully
Saved!
running openssl rsa -inform PEM -in 3D0020000347343339373536_rsa_new.pub.pem -pubout -outform PEM -out /var/folders/sy/trb7qvx90hj2fqxfd96xt7n00000gp/T/116212-48975-hdyfbh.pub.pem
running openssl rsa -pubin -inform PEM -in 3D0020000347343339373536_rsa_new.pub.pem -pubout -outform PEM -out /var/folders/sy/trb7qvx90hj2fqxfd96xt7n00000gp/T/116212-48975-hdyfbh.pub.pem
attempting to add a new public key for device 3D0020000347343339373536
Make sure your device is in DFU mode (blinking yellow), and that your computer is online.
Error - undefined
So this seems to be in the wrong place even though I was getting the same sort of symptoms as the original poster but with an Electron not a Photon - will start a new thread.
…it went all the way through the routine, ended with this:
…attempting to add a new public key for device 3D0020000347343339373536
submitting public key succeeded!
Okay! New keys in place, your device should restart.
The device did restart, went through the wifi connection routine, but still ended up caught in that cyan / red loop.
I tried resetting the wifi credentials via “particle serial wifi” command, still ended up caught in that cyan / red loop.
