Photon S.O.S with working App
I have 5 Particle Photon devices, i’ve flashed each 1 of them with the same software and 4 of them work perfectly, but the 5th i get an S.O.S with 1 flash in between.
i can put it into safe mode and flash tinker on to it so i dont think its a hardware fault but the code stops flashing on the photon much sooner than the other devices. is there a way i can run through a compiler to see whats wrong.
I must say thank you to pblesi for the code which i’ve amended.
I guess you rather mean a way for debugging - rerunning the compiler wouldn't help by any stretch.
There in fact is a way of in-circuit debugging, but that would require extra hardware and OpenOCD.
See here https://docs.particle.io/support/particle-tools-faq/jtag/
Seeing your code would help to maybe spot a potential cause.
 * Project: touch_light
 * Description: A touch light that syncs with other touch lights. Adapted from
 *              http://www.instructables.com/id/Networked-RGB-Wi-Fi-Decorative-Touch-Lights/
 * Author: Patrick Blesi
 * Date: 2017-12-09
#include "neopixel.h"
#include "application.h"
#include "wifi_creds.h"
// CONFIGURATION SETTINGS START
// DEBUG SETTINGS:
#define D_SERIAL false
#define D_WIFI false
String touchEventName = "touch_event";
#define NUM_PARTICLES 5 // number of touch lights in your group
// Number each Filimin starting at 1.
String particleId[] = {
  "1d002d000947363339343638", // NannyB
  "1a002f000a47363339343638", // Spare1
  "39003a001347343432313031", // Nicole
  "250043000947343337373738", // Johnsons
  "1b002b000947363339343638"  // Spare2
int particleColors[] = {
  0,   // Green
  215, //unknown
  90,  // Purple
  170, // Blue
  79  // Orange
// TWEAKABLE VALUES FOR CAP SENSING. THE BELOW VALUES WORK WELL AS A STARTING PLACE:
// BASELINE_VARIANCE: The higher the number the less the baseline is affected by
// current readings. (was 4)
#define BASELINE_VARIANCE 512.0
// SENSITIVITY: Integer. Higher is more sensitive (was 8)
#define SENSITIVITY 8
// BASELINE_SENSITIVITY: Integer. A trigger point such that values exceeding this point
// will not affect the baseline. Higher values make the trigger point sooner. (was 16)
#define BASELINE_SENSITIVITY 16
// SAMPLE_SIZE: Number of samples to take for one reading. Higher is more accurate
// but large values cause some latency.(was 32)
#define SAMPLE_SIZE 512
#define SAMPLES_BETWEEN_PIXEL_UPDATES 32
#define LOOPS_TO_FINAL_COLOR 150
const int minMaxColorDiffs[2][2] = {
  {5,20},   // min/Max if color change last color change from same touch light
  {50,128}  // min/Max if color change last color change from different touch light
// END VALUE, TIME
// 160 is approximately 1 second
const long envelopes[6][2] = {
  {0, 0},      // NOT USED
  {255, 30},   // ATTACK
  {200, 240},  // DECAY
  {200, 1000}, // SUSTAIN
  {150, 60},   // RELEASE1
  {0, 1000000} // RELEASE2 (65535 is about 6'45")
#define PERIODIC_UPDATE_TIME 5 // seconds
#define COLOR_CHANGE_WINDOW 10 // seconds
// CONFIGURATION SETTINGS END
// STATES:
#define ATTACK 1
#define DECAY 2
#define SUSTAIN 3
#define RELEASE1 4
#define RELEASE2 5
#define OFF 6
#define LOCAL_CHANGE 0
#define REMOTE_CHANGE 1
#define END_VALUE 0
#define TIME 1
#define tEVENT_NONE 0
#define tEVENT_TOUCH 1
#define tEVENT_RELEASE 2
String eventTypes[] = {
  "None",
  "Touch",
  "Release"
int sPin = D5;
int rPin = D3;
// NEOPIXEL
#define PIXEL_PIN D2
#define PIXEL_COUNT 24
#define PIXEL_TYPE WS2812B
// STATE
unsigned char myId = 0;
int currentEvent = tEVENT_NONE;
int eventTime = Time.now();
int eventTimePrecision = random(INT_MAX);
int initColor = 0;
int currentColor = 0; // 0 to 255
int finalColor = 0;   // 0 to 255
int lastLocalColorChangeTime = Time.now();
int initBrightness = 0;    // 0 to 255
int currentBrightness = 0; // 0 to 255
unsigned char prevState = OFF;
unsigned char state = OFF;
unsigned char lastColorChangeDeviceId = 1;
long loopCount = 0;
long colorLoopCount = 0;
int lastPeriodicUpdate = Time.now();
// timestamps
unsigned long tS;
volatile unsigned long tR;
// reading and baseline
float tBaseline;
double tDelayExternal = 0;
double tBaselineExternal = 0;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
#ifdef WIFI_CREDENTIALS_SPECIFIED
SYSTEM_MODE(SEMI_AUTOMATIC);
#endif
  setupWifi();
#endif
  Particle.subscribe(touchEventName, handleTouchEvent, MY_DEVICES);
  if (D_SERIAL) Serial.begin(9600);
  if (D_WIFI) {
    Particle.variable("tDelay", &tDelayExternal, DOUBLE);
    Particle.variable("tBaseline", &tBaselineExternal, DOUBLE);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  pinMode(sPin, OUTPUT);
  attachInterrupt(rPin, touchSense, RISING);
  myId = getMyId(particleId, NUM_PARTICLES);
  flashWhite(&strip);
  // Calibrate touch sensor- Keep hands off!!!
  tBaseline = touchSampling(); // initialize to first reading
  if (D_WIFI) tBaselineExternal = tBaseline;
  traverseColorWheel(&strip);
  fade(&strip);
  int touchEvent = touchEventCheck();
  if (touchEvent == tEVENT_NONE) {
    // Publish periodic updates to synchronize state
    bool touchedBefore = currentEvent != tEVENT_NONE;
    if (lastPeriodicUpdate < Time.now() - PERIODIC_UPDATE_TIME && touchedBefore) {
      publishTouchEvent(currentEvent, finalColor, eventTime, eventTimePrecision);
    return;
  // Random eventTimePrecision prevents ties with other
  // server events. This allows us to determine dominant
  // color in the event of ties.
  setEvent(touchEvent, Time.now(), random(INT_MAX));
  if (D_SERIAL) Serial.println(eventTypes[touchEvent]);
  if (touchEvent == tEVENT_TOUCH) {
    int newColor = generateColor(finalColor, prevState, lastColorChangeDeviceId);
    setColor(newColor, prevState, myId);
    changeState(ATTACK, LOCAL_CHANGE);
//	Setup functions
// Functions used during setup
void setupWifi() {
  WiFi.on();
  WiFi.disconnect();
  WiFi.clearCredentials();
  int numWifiCreds = sizeof(wifiCreds) / sizeof(*wifiCreds);
  for (int i = 0; i < numWifiCreds; i++) {
    credentials creds = wifiCreds[i];
    WiFi.setCredentials(creds.ssid, creds.password, creds.authType, creds.cipher);
  WiFi.connect();
  waitUntil(WiFi.ready);
  Particle.connect();
int getMyId(String particleId[], int numParticles) {
  int id = 0;
  for (int i = 1; i <= numParticles; i++) {
    if (!particleId[i].compareTo(Particle.deviceID())) {
      id = i;
      break;
  return id;
void flashWhite(Adafruit_NeoPixel* strip) {
  int numPixels = strip->numPixels();
  for (byte j = 0; j < numPixels; j++) {
    strip->setPixelColor(j, 255, 255, 255);
  strip->show();
  delay(250);
    strip->setPixelColor(j, 0, 0, 0);
  strip->show();
  delay(250);
void traverseColorWheel(Adafruit_NeoPixel* strip) {
  for (int i = 0; i < 256; i++) {
    uint32_t color = wheelColor(i, 255);
      strip->setPixelColor(j, color);
      strip->show();
    delay(1);
void fade(Adafruit_NeoPixel* strip) {
  for (int j = 255; j >= 0; j--) {
    uint32_t color = wheelColor(255, j);
    for (byte k = 0; k < numPixels; k++) {
      strip->setPixelColor(k, color);
      strip->show();
    delay(1);
// touch sampling
// sample touch sensor SAMPLE_SIZE times and get average RC delay [usec]
long touchSampling() {
  long tDelay = 0;
  int mSample = 0;
  for (int i = 0; i < SAMPLE_SIZE; i++) {
    if (!(i % SAMPLES_BETWEEN_PIXEL_UPDATES)) {
      updateState();
    pinMode(rPin, OUTPUT); // discharge capacitance at rPin
    digitalWrite(sPin,LOW);
    digitalWrite(rPin,LOW);
    pinMode(rPin,INPUT); // revert to high impedance input
    // timestamp & transition sPin to HIGH and wait for interrupt in a read loop
    tS = micros();
    tR = tS;
    digitalWrite(sPin,HIGH);
    do {
      // wait for transition
    } while (digitalRead(rPin)==LOW);
    // accumulate the RC delay samples
    // ignore readings when micros() overflows
    if (tR > tS) {
      tDelay = tDelay + (tR - tS);
      mSample++;
  // calculate average RC delay [usec]
  if ((tDelay > 0) && (mSample > 0)) {
    tDelay = tDelay/mSample;
  } else {
    tDelay = 0;     // this is an error condition!
  if (D_SERIAL) Serial.println(tDelay);
  if (D_WIFI) tDelayExternal = tDelay;
  // autocalibration using exponential moving average on data below specified point
  if (tDelay < (tBaseline + tBaseline/BASELINE_SENSITIVITY)) {
    tBaseline = tBaseline + (tDelay - tBaseline)/BASELINE_VARIANCE;
  return tDelay;
//	Touch UI
// ISR for touch sensing
void touchSense() {
  tR = micros();
// touch event check
// check touch sensor for events:
//      tEVENT_NONE     no change
//      tEVENT_TOUCH    sensor is touched (Low to High)
//      tEVENT_RELEASE  sensor is released (High to Low)
int touchEventCheck() {
  int touchSense;                     // current reading
  static int touchSenseLast = LOW;    // last reading
  static unsigned long touchDebounceTimeLast = 0; // debounce timer
  int touchDebounceTime = 50;                     // debounce time
  static int touchNow = LOW;  // current debounced state
  static int touchLast = LOW; // last debounced state
  int tEvent = tEVENT_NONE;   // default event
  // read touch sensor
  long tReading = touchSampling();
  // touch sensor is HIGH if trigger point some threshold above Baseline
  if (tReading > (tBaseline + tBaseline / SENSITIVITY)) {
    touchSense = HIGH;
  } else {
    touchSense = LOW;
  // debounce touch sensor
  // if state changed then reset debounce timer
  if (touchSense != touchSenseLast) {
    touchDebounceTimeLast = millis();
  touchSenseLast = touchSense;
  // accept as a stable sensor reading if the debounce time is exceeded without reset
  if (millis() > touchDebounceTimeLast + touchDebounceTime) {
    touchNow = touchSense;
  // set events based on transitions between readings
  if (!touchLast && touchNow) {
    tEvent = tEVENT_TOUCH;
  if (touchLast && !touchNow) {
    tEvent = tEVENT_RELEASE;
  // update last reading
  touchLast = touchNow;
  return tEvent;
void setEvent(int event, int timeOfEvent, int timePrecision) {
  currentEvent = event;
  eventTime = timeOfEvent;
  eventTimePrecision = timePrecision;
void handleTouchEvent(const char *event, const char *data) {
  String eventData = String(data);
  int deviceIdEnd = eventData.indexOf(',');
  int deviceId = eventData.substring(0, deviceIdEnd).toInt();
  int eventEnd = eventData.indexOf(',', deviceIdEnd + 1);
  int serverEvent = eventData.substring(deviceIdEnd + 1, eventEnd).toInt();
  int colorEnd = eventData.indexOf(',', eventEnd + 1);
  int serverColor = eventData.substring(eventEnd + 1, colorEnd).toInt();
  int eventTimeEnd = eventData.indexOf(',', colorEnd + 1);
  int serverEventTime = eventData.substring(colorEnd + 1, eventTimeEnd).toInt();
  int serverEventTimePrecision = eventData.substring(eventTimeEnd + 1).toInt();
  if (false) {
    String response = "deviceId: " + String(deviceId) + " " +
                      "serverEvent: " + String(serverEvent) + " " +
                      "serverColor: " + String(serverColor) + " " +
                      "localEventTime: " + String(eventTime) + " " +
                      "serverEventTime: " + String(serverEventTime) + " " +
                      "serverEventTimePrecision: " + String(serverEventTimePrecision);
    Particle.publish("touch_response", response, 61, PRIVATE);
  if (deviceId == myId) return;
  if (serverEventTime < eventTime) return;
  // Race condition brought colors out of sync
  if (
    serverEventTime == eventTime &&
    serverEventTimePrecision == eventTimePrecision &&
    serverColor != finalColor &&
    myId < deviceId
    setColor(serverColor, prevState, deviceId);
    changeState(ATTACK, REMOTE_CHANGE);
    return;
  if (serverEventTime == eventTime && serverEventTimePrecision <= eventTimePrecision) return;
  // Valid remote update
  setEvent(serverEvent, serverEventTime, serverEventTimePrecision);
  if (serverEvent == tEVENT_TOUCH) {
  } else {
    changeState(RELEASE1, REMOTE_CHANGE);
void setColor(int color, unsigned char prevState, unsigned char deviceId) {
  lastColorChangeDeviceId = deviceId;
  if (prevState == OFF) currentColor = color;
  initColor = currentColor;
  finalColor = color;
  colorLoopCount = 0;
  if (D_SERIAL) {
    Serial.print("get Color From Server Final color: ");
    Serial.print(initColor);
    Serial.print(", ");
    Serial.print(finalColor);
    Serial.print(", ");
int generateColor(int currentFinalColor, unsigned char prevState, int lastColorChangeDeviceId) {
  int color = 0;
  int now = Time.now();
  Serial.println("generating color...");
  if (prevState == OFF || lastLocalColorChangeTime < now - COLOR_CHANGE_WINDOW) {
    color = particleColors[myId];
  } else {
    bool foreignId = (lastColorChangeDeviceId != myId);
    int minChange = minMaxColorDiffs[foreignId][0];
    int maxChange = minMaxColorDiffs[foreignId][1];
    int direction = random(2) * 2 - 1;
    int magnitude = random(minChange, maxChange + 1);
    color = currentFinalColor + direction * magnitude;
    color = (color + 256) % 256;
    // color = 119; // FORCE A COLOR
  lastLocalColorChangeTime = now;
  if (D_SERIAL) { Serial.print("final color: "); Serial.println(finalColor); }
  return color;
void changeState(unsigned char newState, int remoteChange) {
  prevState = state;
  state = newState;
  initBrightness = currentBrightness;
  loopCount = 0;
  if (D_SERIAL) { Serial.print("state: "); Serial.println(newState); }
  if (remoteChange) return;
  if (newState == ATTACK || newState == RELEASE1) {
void publishTouchEvent(int event, int color, int time, int timePrecision) {
  String response = String(myId)  + "," +
                    String(event) + "," +
                    String(color) + "," +
                    String(time)  + "," +
                    String(timePrecision);
  Particle.publish(touchEventName, response, 60, PRIVATE);
void updateState() {
  switch (state) {
    case ATTACK:
      if (loopCount >= envelopes[ATTACK][TIME]) {
        changeState(DECAY, LOCAL_CHANGE);
      break;
    case DECAY:
      if ((loopCount >= envelopes[DECAY][TIME]) || (currentEvent == tEVENT_RELEASE)) {
        changeState(SUSTAIN, LOCAL_CHANGE);
      break;
    case SUSTAIN:
      if ((loopCount >= envelopes[SUSTAIN][TIME]) || (currentEvent == tEVENT_RELEASE)) {
        changeState(RELEASE1, LOCAL_CHANGE);
      break;
    case RELEASE1:
      if (loopCount >= envelopes[RELEASE1][TIME]) {
        changeState(RELEASE2, LOCAL_CHANGE);
      break;
    case RELEASE2:
      if (loopCount >= envelopes[RELEASE2][TIME]) {
        changeState(OFF, LOCAL_CHANGE);
      break;
  currentBrightness = getCurrentBrightness(state, initBrightness, loopCount);
  if (currentColor != finalColor) {
    currentColor = getCurrentColor(finalColor, initColor, colorLoopCount);
  uint32_t colorAndBrightness = wheelColor(currentColor, currentBrightness);
  updateNeoPixels(colorAndBrightness);
  loopCount++;
  colorLoopCount++;
int getCurrentBrightness(unsigned char state, int initBrightness, int loopCount) {
  if (state == OFF) return 0;
  int brightnessDistance = envelopes[state][END_VALUE] - initBrightness;
  int brightnessDistanceXElapsedTime = brightnessDistance * loopCount / envelopes[state][TIME];
  return min(255, max(0, initBrightness + brightnessDistanceXElapsedTime));
int getCurrentColor(int finalColor, int initColor, int colorLoopCount) {
  if (colorLoopCount > LOOPS_TO_FINAL_COLOR) return finalColor;
  int colorDistance = calcColorChange(initColor, finalColor);
  int colorDistanceXElapsedTime = colorDistance * colorLoopCount / LOOPS_TO_FINAL_COLOR;
  return (256 + initColor + colorDistanceXElapsedTime) % 256;
int calcColorChange(int currentColor, int finalColor) {
  int colorChange = finalColor - currentColor;
  int direction = (colorChange < 0) * 2 - 1;
  colorChange += direction * (abs(colorChange) > 127) * 256;
  return colorChange;
void updateNeoPixels(uint32_t color) {
  for(char i = 0; i < strip.numPixels(); i++) {
    strip.setPixelColor(i, color);
  strip.show();
//	NEOPIXEL
// Wheel
uint32_t wheelColor(byte WheelPos, byte iBrightness) {
  float R, G, B;
  float brightness = iBrightness / 255.0;
  if (WheelPos < 85) {
    R = WheelPos * 3;
    G = 255 - WheelPos * 3;
    B = 0;
  } else if (WheelPos < 170) {
    WheelPos -= 85;
    R = 255 - WheelPos * 3;
    G = 0;
    B = WheelPos * 3;
  } else {
    WheelPos -= 170;
    R = 0;
    G = WheelPos * 3;
    B = 255 - WheelPos * 3;
  R = R * brightness + .5;
  G = G * brightness + .5;
  B = B * brightness + .5;
  return strip.Color((byte) R,(byte) G,(byte) B);
How long is the code running before you hit the SOS panic?
What device OS version are you targeting with that code and what versions are on your devices?
Can you add some Serial.print() statements (with subsequent delay(100)) to get any indication how far the code is running before the crash?
Some hints that probably won’t solve the issue but are still good to adhere
  • Particle.variable("tDelay", &amp;tDelayExternal, DOUBLE); is deprecated syntax, nowadays you’d write Particle.variable("tDelay", tDelayExternal);
  • Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE); is better written as Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
  • You should set pinMode() on your rPin even if you know it’ll be INPUT by default. Also if you are not using a signal source for rPin that provides a discrete HIGH and LOW signal, you should use a pull-down resistor (internal or external) to avoid a flouting pin randomly triggering your interrupt
  • in traverseColorWheel() and fade() you are calling strip->show() too often - take it out of your for() loop
  • it’s better to use if (millis() - touchDebounceTimeLast > touchDebounceTime) than this (millis() > touchDebounceTimeLast + touchDebounceTime)
  • you should avoid String and rather use C strings (aka char[])
  • for string parsing you can use sscanf()
  • for string concatenation use snprintf()
  • you can use Serial.prinlnf() instead of a collection of individual Serial.print() statements
  • make sure envelopes[state][TIME] is never zero to avoid DIV/0 exception in getCurrentBrightness() (e.g. [0][0], [0][1] and [5][0] are declared as 0 and if your unchecked indexes are out of bounds they may cause DIV/0 too)
Forgot to say thank you. The code worked fine on the 1,2,3 and 5 Photon i installed in on but not the 4th, When loading the the working ones i get the purple firmware update, multiple times with flashing green in between (from memory).
When trying to load firmware to the 4th Photon (called Spare1) it get one cycle of purple green then red SOS with 1 red in between. If i boot into safe mode the flash Tinker it seems to work correctly.
Can you run particle serial inspect with that device in Listening Mode and post the output?
You can also try particle update (in DFU Mode) and flash the firmware via particle flash --usb firmware.bin
(the binary can be downloaded from Web IDE via this icon image )
inspect output is below:
Platform: 6 - Photon
Modules
Bootloader module #0 - version 201, main location, 16384 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #1 - version 1002, main location, 262144 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #2 - version 204
System module #2 - version 1002, main location, 262144 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
User module #1 - version 3, main location, 131072 bytes max size
UUID: B3A6DCD529BE70FBE24EE959C7305D58E3BC9A04ACDCE8F093C7A1F759097D09
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #2 - version 6
empty - factory location, 131072 bytes max size
Even flashing via DFU i still get flash successful then green flashing lights, then flashing green much faster then the red. Could it be Wifi Credentials somehow? - Edit, i’ve flashed a version without the preset WiFi credentials and it works, i think although i now need to fit components to it.
