Greetings,
I’ve been using a photon and a DHT22 to monitor temperature and humidity over time with Adafruit.io. Everything is working well, except the photon itself just stops working, and has no LED indication light whatsoever. The power supply to the microUSB is tested known good.
I didn’t find anything from a few searches on this forum and google; any ideas from the community?
It returns to a normal state on reset?
It could be your program that is causing it to get into that funky state.
Yes, it works normally after disconnecting and reconnecting the microUsb cable or pressing the reset button.
How would someone troubleshoot the code going into a ‘funky state’?
