Photon Power Shield - Power Indicator, question
Hello every one,
I am trying to get the Power Shield going, but I am not having the results I expect. Here is a little code that I wrote.
#include <blynk.h>
#include "PowerShield.h"
//#include "Particle.h" // C++ Preprocessor  will not need to add it automatically
//#include "Arduino.h"  // Added to support extended Arduino APIs
BlynkTimer timer;
char auth[] = "xyxyxyxyxyyxyxyx";
PowerShield batteryMonitor;
Blynk.begin(auth, IPAddress(111,222,333,444), 8080);
batteryMonitor.begin(); // This essentially starts the I2C bus
batteryMonitor.quickStart();   // This sets up the fuel gauge
timer.setInterval(1000, CheckBattery);
void CheckBattery()
float cellVoltage = batteryMonitor.getVCell(); // Read the volatge of the LiPo
float stateOfCharge = batteryMonitor.getSoC();// Read the State of Charge of the LiPo
Blynk.virtualWrite(V0, "Voltage : ", cellVoltage, "\n");
Blynk.virtualWrite(V1, "Charge : ", stateOfCharge , "\n");
Blynk.run();
timer.run();
This line:
is suppose to show me the actual voltage of the battery, am I right? Instead, I get a permanent 5 volts indicator, then the battery runs out of power, and that’t it. How can I get the actual voltage?
Thanks.
I suspect what you are really looking for is the state of charge of the battery.
This is not using Blynk but works as far reading battery stats is concerned
(notice, no extra library for the fuel gauge needed anymore)
FuelGauge batteryMonitor;
void CheckBattery();
Timer timer(1000, CheckBattery);
char msg[64];
volatile bool newData = false;
  Serial.begin();
  timer.start();
void CheckBattery()
  float stateOfCharge = batteryMonitor.getSoC();    // Read the State of Charge of the LiPo
  snprintf(msg, sizeof(msg), "Voltage: %.2fV, Charge: %.2f%%", cellVoltage, stateOfCharge);
  Serial.println(msg);
  newData = true;
  if (!newData) return;
  newData = false;
  Particle.publish("Battery", msg, PRIVATE);
Thanks a lot, ScruffR. I will check it out using your suggestion, and report later.
