Photon - Occasionally Stuck at Breathing White After Wake from DEEP SLEEP
I have a Photon that goes to sleep for ~55 seconds and then wakes up, connects to Cloud, takes some measurements, Publish to Cloud, than back to sleep. It is powered from a battery that is backed up with a solar panel.
It always has a strong WiFi signal and good power.
It has been running for over 30 days, but 3 times it has been stuck breathing white and never connects. The power has to be cycled to recover.
What am I doing wrong to cause this issue or what is the recommended way to avoid it? Watch Dog? More startup delay? Check for connection?
My Code:
// INCLUDES
#include "Particle.h"
#include "Particle_MPL115A2.h"
#include "GA1A12S202.h"
#include "DS18B20.h"
#include "Adafruit_DHT_Particle.h"
// STARTUP MACRO
STARTUP(WiFi.selectAntenna(ANT_EXTERNAL));    // selects the u.FL external antenna
//SYSTEM_THREAD(ENABLED);       // Can't use since we need Wifi up to get signal strength
//DEFINES
#define DHTPIN 3            // DHT22 Data  Pin D3
#define DHTTYPE DHT22		    // DHT22 (AM2302)
Particle_MPL115A2 mpl115a2 = Particle_MPL115A2();     // I2C 5V  Pins D0 and D1
GA1A12S202 lux(A0);                                   // Analog  Pin A0
DS18B20  ds18b20(D2, true);                           // Dallas 1-Wire  Pin D2
DHT dht(DHTPIN, DHTTYPE);                             // DHT22 1-Wire  Pin D3
// CONSTANTS
const char      VERSION[] = "P3:Enviro #1 - Solar";   // Device info
const uint32_t  msSAMPLE_D_INTERVAL = 10000;          // Sample Digital Data Rate
const uint32_t  msPUBLISH_INTERVAL  = 20000;         // Publish Rate
const int       MAXRETRY = 5;
const int       SLEEP_RATE = 55;        // Seconds to sleep, Startup and reconnect takes ~12 sec
const bool      useTerm = false;        // Enable/Disable USB-Serial Terminal with output
const bool      pubData = true;         // Enable/Disable Publishing of Data to Particle Cloud
const float     VRef = 3.36;            // this should be measured to calibrate the readings
const float     voltageDivider = 0.75;
// VARIABLES
char      szInfo[64];
float     DHT_TempC = 0.00;
float     DHT_Humidity = 0.00;
int       rssi = 0;
int       wifi_level = 0;
float     MPL115A2_pressureKPA = 0.00;
float     MPL115A2_pressurePSI = 0.00;
float     MPL115A2_temperatureC = 0.00;
float     GA1A12S202_Raw = 0.00;
float     GA1A12S202_Lux = 0.00;
double    DS18B20_temperatureC = 0.00;
uint32_t  msLastSampleD = 0;
float     batteryV = 0.00;
int       A1_reading = 0;
  // USB - Serial
  if (useTerm == 1){
    Serial.begin(115200);
    delay(1000);
    Serial.println("** RESET **");
  // Sensors
  mpl115a2.begin();
  dht.begin();
  // Power ON Delay
  delay(2000);        // NEEDED, DO NOT CHANGE
  // Acquire Data
  // Remove sample loop if deep sleep
  //if (millis() - msLastSampleD >= msSAMPLE_D_INTERVAL){
    // WiFi Signal Level
    rssiWiFi();
    // Data data from GA1A12S202
    //GA1A12S202_Raw = lux.getRaw();
    GA1A12S202_Lux = lux.getLux(true);
    // Data data from MPL115A2
    // Convert kPa to psi:  divide kPa by 6.895
    mpl115a2.getPT(&MPL115A2_pressureKPA,&MPL115A2_temperatureC);
    //MPL115A2_pressurePSI = MPL115A2_pressureKPA/6.895;
    // Get data from DS18B20
    getDS18B20();
    if ((isnan(DS18B20_temperatureC)) ||
        (DS18B20_temperatureC > 75) ||
        (DS18B20_temperatureC < -50)
         delay(100);
         getDS18B20();
    // Data data from DHT22
    DHT_Humidity = dht.getHumidity();
    delay(100);
	  DHT_TempC = dht.getTempCelcius();
    if((isnan(DHT_Humidity)) ||
       (DHT_Humidity > 100) ||
       (DHT_Humidity < 0) ||
       (isnan(DHT_TempC)) ||
       (DHT_TempC > 75) ||
       (DHT_TempC < -50)
        delay(2000);
        delay(100);
    // Power OFF Sensors
    // Measure Battery Voltage
    A1_reading = analogRead(A1);
    delay(250);
    batteryV = (((float)A1_reading / 4095.0) * VRef) / voltageDivider;
    //batteryV = 1.23;
    // Print Data
    if (useTerm == true){
      printData();
    // Publish Data
    if (pubData == true){
      if (Particle.connected()){
        publishData();
    //* DEEP SLEEP MODE - DISABLES WIFI - NO OTA UPDATES
    System.sleep(SLEEP_MODE_DEEP, SLEEP_RATE);
// FUNCTIONS
// Publish Data to Particle Cloud
void publishData(){
  sprintf(szInfo, "%.2f:%.1f:%.0f:%.1f:%.1f:%.1f:%i:%d:%.3f",
      MPL115A2_temperatureC,
      GA1A12S202_Lux,
      DHT_Humidity,
      DHT_TempC,
      DS18B20_temperatureC,
      rssi,
      wifi_level,
      batteryV
  Particle.publish("Main_Data", szInfo, PRIVATE);
  //Serial.println(szInfo);
void printData(){
  Serial.println("----------------------------------");
  Serial.print("MPL115A2 - Pressure: "); Serial.print(MPL115A2_pressurePSI, 2); Serial.println(" psi");
  Serial.print("MPL115A2 - Temperature: "); Serial.print(MPL115A2_temperatureC, 1); Serial.println(" degC");
  Serial.print("GA1A12S202 - Lux: "); Serial.print(GA1A12S202_Lux, 0); Serial.println(" lux");
  Serial.print("DHT22 - Humidity: "); Serial.print(DHT_Humidity, 1); Serial.println(" %");
  Serial.print("DHT22 - Temperature: "); Serial.print(DHT_TempC, 1); Serial.println(" degC");
  Serial.print("DS18B20 - Temperature: "); Serial.print(DS18B20_temperatureC, 1); Serial.println(" degC");
  Serial.print("WiFi - RSSI: "); Serial.println(rssi);
  Serial.print("WiFi - Level: "); Serial.println(wifi_level);
  Serial.print("Battery Voltage: "); Serial.println(batteryV);
void getDS18B20(){
  float _temp;
  int   i = 0;
  do {
    _temp = ds18b20.getTemperature();
  } while (!ds18b20.crcCheck() && MAXRETRY > i++);
  if (i < MAXRETRY) {
    DS18B20_temperatureC = _temp;
  else {
    DS18B20_temperatureC = NAN;
void rssiWiFi(){
  rssi = WiFi.RSSI();       // -127 (weak) to -1dB (strong)
  if (rssi < 0) {
				if (rssi > -40) {
					//Serial.println("Signal strength is Strong RSSI: "+String(rssi)+"dB.");
          wifi_level = 5;
				else
				if (rssi > -65) {
					//Serial.println("Signal strength is OK - RSSI: "+String(rssi)+"dB.");
					wifi_level = 4;
				else
				if (rssi > -75) {
					wifi_level = 3;
				else
				if (rssi > -90) {
					//Serial.println("Signal strength is Weak - RSSI: "+String(rssi)+"dB.");
					wifi_level = 2;
				else {
					//Serial.println("Signal strength is Poor - RSSI: "+String(rssi)+"dB.");
					wifi_level = 1;
			else {
				// This case runs when WiFi is disconnected
        //Serial.println("Wifi is disconnected. RSSI: "+String(rssi)+"dB.");
				wifi_level = 0;
Quick observations:
Add SYSTEM_THREAD(ENABLED); macro
Personally I would add SYSTEM_MODE(SEMI_AUTOMATIC);
Then you should check for WiFi ready after a Wifi connect - sometimes the WiFi could drop just as you restart? You could implementation a timeout and retry. This also allows you to know if one of the sensors is causing the restart issue or the reconnection.
Adding an application watchdog would definitely help catch the problem after the exit from deep sleep and the restart - it would also help you understand where it is stopping if you could apply a trace.
