Photon not connecting to wifi (blinking blue)
I have 3 photons now doing the same thing, they are all connected to my work wifi, but when I try to connect them to another wifi, making sure the LED is blinking blue, I get “connecting to photon” then an error “please try running setup again after resetting your photon and putting it back in blinking blue listen mode if needed.” I have tried doing this several times with the two I have with me, and nothing changes. On the third, I have reflashed tinker over the CLI and it is all but useless now, I cannot connect it to any other network and it doesn’t allow OTA updates. Any ideas?
Could you try placing it in Safe Mode first, and then going into Listening mode? It might be that your own code is interfering.
Neither photon will enter safe mode, holding down both buttons, releasing reset, holding setup until it flashes magenta, then releasing setup, it flashes white once then blinks green. It never gets to breathing magenta as stated in the docs.
Here is my code on one of them, the only thing they have in common is the softap https page, is there something wrong in the code that keeps it in an infinite loop or something interfering with the wifi connect?
#pragma SPARK_NO_PREPROCESSOR
#include "Particle.h"
#include "softap_http.h"
int button = D6;
struct Page
    const char* url;
    const char* mime_type;
    const char* data;
const char index_html[] = "<!DOCTYPE html><html><head><meta name='viewport' content='width=device-width, initial-scale=1'><title>Setup your device</title><link rel='stylesheet' type='text/css' href='style.css'></head><body><h1>Connect Janus to your WiFi!</h1><h3>My device ID:</h3><input type=text id='device-id' size='25' value='' disabled/><button type='button' class='input-helper' id='copy-button'>Copy</button><div id='scan-div'><h3>Scan for visible WiFi networks</h3><button id='scan-button' type='button'>Scan</button></div><div id='networks-div'></div><div id='connect-div' style='display: none'><p>Don't see your network? Move me closer to your router, then re-scan.</p><form id='connect-form'><input type='password' id='password' size='25' placeholder='password'/><button type='button' class='input-helper' id='show-button'>Show</button><button type='submit' id='connect-button'>Connect</button></form></div><script src='rsa-utils/jsbn_1.js'></script><script src='rsa-utils/jsbn_2.js'></script><script src='rsa-utils/prng4.js'></script><script src='rsa-utils/rng.js'></script><script src='rsa-utils/rsa.js'></script><script src='script.js'></script></body></html>";
const char rsa_js[] = "function parseBigInt(a,b){return new BigInteger(a,b);}function linebrk(a,b){var c='';var d=0;while(d+b<a.length){c+=a.substring(d,d+b)+'\\n';d+=b;}return c+a.substring(d,a.length);}function byte2Hex(a){if(a<0x10)return '0'+a.toString(16);else return a.toString(16);}function pkcs1pad2(a,b){if(b<a.length+11){alert('Message too long for RSA');return null;}var c=new Array();var d=a.length-1;while(d>=0&&b>0){var e=a.charCodeAt(d--);if(e<128)c[--b]=e;else if((e>127)&&(e<2048)){c[--b]=(e&63)|128;c[--b]=(e>>6)|192;}else{c[--b]=(e&63)|128;c[--b]=((e>>6)&63)|128;c[--b]=(e>>12)|224;}}c[--b]=0;var f=new SecureRandom();var g=new Array();while(b>2){g[0]=0;while(g[0]==0)f.nextBytes(g);c[--b]=g[0];}c[--b]=2;c[--b]=0;return new BigInteger(c);}function RSAKey(){this.n=null;this.e=0;this.d=null;this.p=null;this.q=null;this.dmp1=null;this.dmq1=null;this.coeff=null;}function RSASetPublic(a,b){if(a!=null&&b!=null&&a.length>0&&b.length>0){this.n=parseBigInt(a,16);this.e=parseInt(b,16);}else alert('Invalid RSA public key');}function RSADoPublic(a){return a.modPowInt(this.e,this.n);}function RSAEncrypt(a){var b=pkcs1pad2(a,(this.n.bitLength()+7)>>3);if(b==null)return null;var c=this.doPublic(b);if(c==null)return null;var d=c.toString(16);if((d.length&1)==0)return d;else return '0'+d;}RSAKey.prototype.doPublic=RSADoPublic;RSAKey.prototype.setPublic=RSASetPublic;RSAKey.prototype.encrypt=RSAEncrypt;";
const char style_css[] = "html{height:100%;margin:auto;background-color:white}body{box-sizing:border-box;min-height:100%;padding:20px;background-color:#1843ec;font-family:'Lucida Sans Unicode','Lucida Grande',sans-serif;font-weight:normal;color:white;margin-top:0;margin-left:auto;margin-right:auto;margin-bottom:0;max-width:400px;text-align:center;border:1px solid #6e6e70;border-radius:4px}div{margin-top:25px;margin-bottom:25px}h1{margin-top:25px;margin-bottom:25px}button{border-color:#1c75be;background-color:#1c75be;color:white;border-radius:5px;height:30px;font-size:15px;font-weight:bold}button.input-helper{background-color:#bebebe;border-color:#bebebe;color:#6e6e70;margin-left:3px}button:disabled{background-color:#bebebe;border-color:#bebebe;color:white}input[type='text'],input[type='password']{background-color:white;color:#6e6e70;border-color:white;border-radius:5px;height:25px;text-align:center;font-size:15px}input:disabled{background-color:#bebebe;border-color:#bebebe}input[type='radio']{position:relative;bottom:-0.33em;margin:0;border:0;height:1.5em;width:15%}label{padding-top:7px;padding-bottom:7px;padding-left:5%;display:inline-block;width:80%;text-align:left}input[type='radio']:checked+label{font-weight:bold;color:#1c75be}.scanning-error{font-weight:bold;text-align:center}.radio-div{box-sizing:border-box;margin:2px;margin-left:auto;margin-right:auto;background-color:white;color:#6e6e70;border:1px solid #6e6e70;border-radius:3px;width:100%;padding:5px}#networks-div{margin-left:auto;margin-right:auto;text-align:left}#device-id{text-align:center}#scan-button{min-width:100px}#connect-button{display:block;min-width:100px;margin-top:10px;margin-left:auto;margin-right:auto;margin-bottom:20px}#password{margin-top:20px;margin-bottom:10px}";
const char rng_js[] = "var rng_state;var rng_pool;var rng_pptr;function rng_seed_int(a){rng_pool[rng_pptr++]^=a&255;rng_pool[rng_pptr++]^=(a>>8)&255;rng_pool[rng_pptr++]^=(a>>16)&255;rng_pool[rng_pptr++]^=(a>>24)&255;if(rng_pptr>=rng_psize)rng_pptr-=rng_psize;}function rng_seed_time(){rng_seed_int(new Date().getTime());}if(rng_pool==null){rng_pool=new Array();rng_pptr=0;var t;if(window.crypto&&window.crypto.getRandomValues){var ua=new Uint8Array(32);window.crypto.getRandomValues(ua);for(t=0;t<32;++t)rng_pool[rng_pptr++]=ua[t];}if(navigator.appName=='Netscape'&&navigator.appVersion<'5'&&window.crypto){var z=window.crypto.random(32);for(t=0;t<z.length;++t)rng_pool[rng_pptr++]=z.charCodeAt(t)&255;}while(rng_pptr<rng_psize){t=Math.floor(65536*Math.random());rng_pool[rng_pptr++]=t>>>8;rng_pool[rng_pptr++]=t&255;}rng_pptr=0;rng_seed_time();}function rng_get_byte(){if(rng_state==null){rng_seed_time();rng_state=prng_newstate();rng_state.init(rng_pool);for(rng_pptr=0;rng_pptr<rng_pool.length;++rng_pptr)rng_pool[rng_pptr]=0;rng_pptr=0;}return rng_state.next();}function rng_get_bytes(a){var b;for(b=0;b<a.length;++b)a[b]=rng_get_byte();}function SecureRandom(){}SecureRandom.prototype.nextBytes=rng_get_bytes;";
const char jsbn_2_js[] = "function bnpRShiftTo(a,b){b.s=this.s;var c=Math.floor(a/this.DB);if(c>=this.t){b.t=0;return;}var d=a%this.DB;var e=this.DB-d;var f=(1<<d)-1;b[0]=this[c]>>d;for(var g=c+1;g<this.t;++g){b[g-c-1]|=(this[g]&f)<<e;b[g-c]=this[g]>>d;}if(d>0)b[this.t-c-1]|=(this.s&f)<<e;b.t=this.t-c;b.clamp();}function bnpSubTo(a,b){var c=0,d=0,e=Math.min(a.t,this.t);while(c<e){d+=this[c]-a[c];b[c++]=d&this.DM;d>>=this.DB;}if(a.t<this.t){d-=a.s;while(c<this.t){d+=this[c];b[c++]=d&this.DM;d>>=this.DB;}d+=this.s;}else{d+=this.s;while(c<a.t){d-=a[c];b[c++]=d&this.DM;d>>=this.DB;}d-=a.s;}b.s=(d<0)?-1:0;if(d<-1)b[c++]=this.DV+d;else if(d>0)b[c++]=d;b.t=c;b.clamp();}function bnpMultiplyTo(a,b){var c=this.abs(),d=a.abs();var e=c.t;b.t=e+d.t;while(--e>=0)b[e]=0;for(e=0;e<d.t;++e)b[e+c.t]=c.am(0,d[e],b,e,0,c.t);b.s=0;b.clamp();if(this.s!=a.s)BigInteger.ZERO.subTo(b,b);}function bnpSquareTo(a){var b=this.abs();var c=a.t=2*b.t;while(--c>=0)a[c]=0;for(c=0;c<b.t-1;++c){var d=b.am(c,b[c],a,2*c,0,1);if((a[c+b.t]+=b.am(c+1,2*b[c],a,2*c+1,d,b.t-c-1))>=b.DV){a[c+b.t]-=b.DV;a[c+b.t+1]=1;}}if(a.t>0)a[a.t-1]+=b.am(c,b[c],a,2*c,0,1);a.s=0;a.clamp();}function bnpDivRemTo(a,b,c){var d=a.abs();if(d.t<=0)return;var e=this.abs();if(e.t<d.t){if(b!=null)b.fromInt(0);if(c!=null)this.copyTo(c);return;}if(c==null)c=nbi();var f=nbi(),g=this.s,h=a.s;var i=this.DB-nbits(d[d.t-1]);if(i>0){d.lShiftTo(i,f);e.lShiftTo(i,c);}else{d.copyTo(f);e.copyTo(c);}var j=f.t;var k=f[j-1];if(k==0)return;var l=k*(1<<this.F1)+((j>1)?f[j-2]>>this.F2:0);var m=this.FV/l,n=(1<<this.F1)/l,o=1<<this.F2;var p=c.t,q=p-j,r=(b==null)?nbi():b;f.dlShiftTo(q,r);if(c.compareTo(r)>=0){c[c.t++]=1;c.subTo(r,c);}BigInteger.ONE.dlShiftTo(j,r);r.subTo(f,f);while(f.t<j)f[f.t++]=0;while(--q>=0){var s=(c[--p]==k)?this.DM:Math.floor(c[p]*m+(c[p-1]+o)*n);if((c[p]+=f.am(0,s,c,q,0,j))<s){f.dlShiftTo(q,r);c.subTo(r,c);while(c[p]<--s)c.subTo(r,c);}}if(b!=null){c.drShiftTo(j,b);if(g!=h)BigInteger.ZERO.subTo(b,b);}c.t=j;c.clamp();if(i>0)c.rShiftTo(i,c);if(g<0)BigInteger.ZERO.subTo(c,c);}function bnMod(a){var b=nbi();this.abs().divRemTo(a,null,b);if(this.s<0&&b.compareTo(BigInteger.ZERO)>0)a.subTo(b,b);return b;}function Classic(a){this.m=a;}function cConvert(a){if(a.s<0||a.compareTo(this.m)>=0)return a.mod(this.m);else return a;}function cRevert(a){return a;}function cReduce(a){a.divRemTo(this.m,null,a);}function cMulTo(a,b,c){a.multiplyTo(b,c);this.reduce(c);}function cSqrTo(a,b){a.squareTo(b);this.reduce(b);}Classic.prototype.convert=cConvert;Classic.prototype.revert=cRevert;Classic.prototype.reduce=cReduce;Classic.prototype.mulTo=cMulTo;Classic.prototype.sqrTo=cSqrTo;function bnpInvDigit(){if(this.t<1)return 0;var a=this[0];if((a&1)==0)return 0;var b=a&3;b=(b*(2-(a&0xf)*b))&0xf;b=(b*(2-(a&0xff)*b))&0xff;b=(b*(2-(((a&0xffff)*b)&0xffff)))&0xffff;b=(b*(2-a*b%this.DV))%this.DV;return(b>0)?this.DV-b:-b;}function Montgomery(a){this.m=a;this.mp=a.invDigit();this.mpl=this.mp&0x7fff;this.mph=this.mp>>15;this.um=(1<<(a.DB-15))-1;this.mt2=2*a.t;}function montConvert(a){var b=nbi();a.abs().dlShiftTo(this.m.t,b);b.divRemTo(this.m,null,b);if(a.s<0&&b.compareTo(BigInteger.ZERO)>0)this.m.subTo(b,b);return b;}function montRevert(a){var b=nbi();a.copyTo(b);this.reduce(b);return b;}function montReduce(a){while(a.t<=this.mt2)a[a.t++]=0;for(var b=0;b<this.m.t;++b){var c=a[b]&0x7fff;var d=(c*this.mpl+(((c*this.mph+(a[b]>>15)*this.mpl)&this.um)<<15))&a.DM;c=b+this.m.t;a[c]+=this.m.am(0,d,a,b,0,this.m.t);while(a[c]>=a.DV){a[c]-=a.DV;a[++c]++;}}a.clamp();a.drShiftTo(this.m.t,a);if(a.compareTo(this.m)>=0)a.subTo(this.m,a);}function montSqrTo(a,b){a.squareTo(b);this.reduce(b);}function montMulTo(a,b,c){a.multiplyTo(b,c);this.reduce(c);}Montgomery.prototype.convert=montConvert;Montgomery.prototype.revert=montRevert;Montgomery.prototype.reduce=montReduce;Montgomery.prototype.mulTo=montMulTo;Montgomery.prototype.sqrTo=montSqrTo;function bnpIsEven(){return((this.t>0)?(this[0]&1):this.s)==0;}function bnpExp(a,b){if(a>0xffffffff||a<1)return BigInteger.ONE;var c=nbi(),d=nbi(),e=b.convert(this),f=nbits(a)-1;e.copyTo(c);while(--f>=0){b.sqrTo(c,d);if((a&(1<<f))>0)b.mulTo(d,e,c);else{var g=c;c=d;d=g;}}return b.revert(c);}function bnModPowInt(a,b){var c;if(a<256||b.isEven())c=new Classic(b);else c=new Montgomery(b);return this.exp(a,c);}BigInteger.prototype.copyTo=bnpCopyTo;BigInteger.prototype.fromInt=bnpFromInt;BigInteger.prototype.fromString=bnpFromString;BigInteger.prototype.clamp=bnpClamp;BigInteger.prototype.dlShiftTo=bnpDLShiftTo;BigInteger.prototype.drShiftTo=bnpDRShiftTo;BigInteger.prototype.lShiftTo=bnpLShiftTo;BigInteger.prototype.rShiftTo=bnpRShiftTo;BigInteger.prototype.subTo=bnpSubTo;BigInteger.prototype.multiplyTo=bnpMultiplyTo;BigInteger.prototype.squareTo=bnpSquareTo;BigInteger.prototype.divRemTo=bnpDivRemTo;BigInteger.prototype.invDigit=bnpInvDigit;BigInteger.prototype.isEven=bnpIsEven;BigInteger.prototype.exp=bnpExp;BigInteger.prototype.toString=bnToString;BigInteger.prototype.negate=bnNegate;BigInteger.prototype.abs=bnAbs;BigInteger.prototype.compareTo=bnCompareTo;BigInteger.prototype.bitLength=bnBitLength;BigInteger.prototype.mod=bnMod;BigInteger.prototype.modPowInt=bnModPowInt;BigInteger.ZERO=nbv(0);BigInteger.ONE=nbv(1);";
const char jsbn_1_js[] = "var dbits;var canary=0xdeadbeefcafe;var j_lm=((canary&0xffffff)==0xefcafe);function BigInteger(a,b,c){if(a!=null)if('number'==typeof a)this.fromNumber(a,b,c);else if(b==null&&'string'!=typeof a)this.fromString(a,256);else this.fromString(a,b);}function nbi(){return new BigInteger(null);}function am1(a,b,c,d,e,f){while(--f>=0){var g=b*this[a++]+c[d]+e;e=Math.floor(g/0x4000000);c[d++]=g&0x3ffffff;}return e;}function am2(a,b,c,d,e,f){var g=b&0x7fff,h=b>>15;while(--f>=0){var i=this[a]&0x7fff;var j=this[a++]>>15;var k=h*i+j*g;i=g*i+((k&0x7fff)<<15)+c[d]+(e&0x3fffffff);e=(i>>>30)+(k>>>15)+h*j+(e>>>30);c[d++]=i&0x3fffffff;}return e;}function am3(a,b,c,d,e,f){var g=b&0x3fff,h=b>>14;while(--f>=0){var i=this[a]&0x3fff;var j=this[a++]>>14;var k=h*i+j*g;i=g*i+((k&0x3fff)<<14)+c[d]+e;e=(i>>28)+(k>>14)+h*j;c[d++]=i&0xfffffff;}return e;}if(j_lm&&(navigator.appName=='Microsoft Internet Explorer')){BigInteger.prototype.am=am2;dbits=30;}else if(j_lm&&(navigator.appName!='Netscape')){BigInteger.prototype.am=am1;dbits=26;}else{BigInteger.prototype.am=am3;dbits=28;}BigInteger.prototype.DB=dbits;BigInteger.prototype.DM=((1<<dbits)-1);BigInteger.prototype.DV=(1<<dbits);var BI_FP=52;BigInteger.prototype.FV=Math.pow(2,BI_FP);BigInteger.prototype.F1=BI_FP-dbits;BigInteger.prototype.F2=2*dbits-BI_FP;var BI_RM='0123456789abcdefghijklmnopqrstuvwxyz';var BI_RC=new Array();var rr,vv;rr='0'.charCodeAt(0);for(vv=0;vv<=9;++vv)BI_RC[rr++]=vv;rr='a'.charCodeAt(0);for(vv=10;vv<36;++vv)BI_RC[rr++]=vv;rr='A'.charCodeAt(0);for(vv=10;vv<36;++vv)BI_RC[rr++]=vv;function int2char(a){return BI_RM.charAt(a);}function intAt(a,b){var c=BI_RC[a.charCodeAt(b)];return(c==null)?-1:c;}function bnpCopyTo(a){for(var b=this.t-1;b>=0;--b)a[b]=this[b];a.t=this.t;a.s=this.s;}function bnpFromInt(a){this.t=1;this.s=(a<0)?-1:0;if(a>0)this[0]=a;else if(a<-1)this[0]=a+this.DV;else this.t=0;}function nbv(a){var b=nbi();b.fromInt(a);return b;}function bnpFromString(a,b){var c;if(b==16)c=4;else if(b==8)c=3;else if(b==256)c=8;else if(b==2)c=1;else if(b==32)c=5;else if(b==4)c=2;else{this.fromRadix(a,b);return;}this.t=0;this.s=0;var d=a.length,e=false,f=0;while(--d>=0){var g=(c==8)?a[d]&0xff:intAt(a,d);if(g<0){if(a.charAt(d)=='-')e=true;continue;}e=false;if(f==0)this[this.t++]=g;else if(f+c>this.DB){this[this.t-1]|=(g&((1<<(this.DB-f))-1))<<f;this[this.t++]=(g>>(this.DB-f));}else this[this.t-1]|=g<<f;f+=c;if(f>=this.DB)f-=this.DB;}if(c==8&&(a[0]&0x80)!=0){this.s=-1;if(f>0)this[this.t-1]|=((1<<(this.DB-f))-1)<<f;}this.clamp();if(e)BigInteger.ZERO.subTo(this,this);}function bnpClamp(){var a=this.s&this.DM;while(this.t>0&&this[this.t-1]==a)--this.t;}function bnToString(a){if(this.s<0)return '-'+this.negate().toString(a);var b;if(a==16)b=4;else if(a==8)b=3;else if(a==2)b=1;else if(a==32)b=5;else if(a==4)b=2;else return this.toRadix(a);var c=(1<<b)-1,d,e=false,f='',g=this.t;var h=this.DB-(g*this.DB)%b;if(g-->0){if(h<this.DB&&(d=this[g]>>h)>0){e=true;f=int2char(d);}while(g>=0){if(h<b){d=(this[g]&((1<<h)-1))<<(b-h);d|=this[--g]>>(h+=this.DB-b);}else{d=(this[g]>>(h-=b))&c;if(h<=0){h+=this.DB;--g;}}if(d>0)e=true;if(e)f+=int2char(d);}}return e?f:'0';}function bnNegate(){var a=nbi();BigInteger.ZERO.subTo(this,a);return a;}function bnAbs(){return(this.s<0)?this.negate():this;}function bnCompareTo(a){var b=this.s-a.s;if(b!=0)return b;var c=this.t;b=c-a.t;if(b!=0)return(this.s<0)?-b:b;while(--c>=0)if((b=this[c]-a[c])!=0)return b;return 0;}function nbits(a){var b=1,c;if((c=a>>>16)!=0){a=c;b+=16;}if((c=a>>8)!=0){a=c;b+=8;}if((c=a>>4)!=0){a=c;b+=4;}if((c=a>>2)!=0){a=c;b+=2;}if((c=a>>1)!=0){a=c;b+=1;}return b;}function bnBitLength(){if(this.t<=0)return 0;return this.DB*(this.t-1)+nbits(this[this.t-1]^(this.s&this.DM));}function bnpDLShiftTo(a,b){var c;for(c=this.t-1;c>=0;--c)b[c+a]=this[c];for(c=a-1;c>=0;--c)b[c]=0;b.t=this.t+a;b.s=this.s;}function bnpDRShiftTo(a,b){for(var c=a;c<this.t;++c)b[c-a]=this[c];b.t=Math.max(this.t-a,0);b.s=this.s;}function bnpLShiftTo(a,b){var c=a%this.DB;var d=this.DB-c;var e=(1<<d)-1;var f=Math.floor(a/this.DB),g=(this.s<<c)&this.DM,h;for(h=this.t-1;h>=0;--h){b[h+f+1]=(this[h]>>d)|g;g=(this[h]&e)<<c;}for(h=f-1;h>=0;--h)b[h]=0;b[f]=g;b.t=this.t+f+1;b.s=this.s;b.clamp();}";
const char script_js[] = "var base_url='http://192.168.0.1/';var network_list;var public_key;var rsa=new RSAKey();var scanButton=document.getElementById('scan-button');var connectButton=document.getElementById('connect-button');var copyButton=document.getElementById('copy-button');var showButton=document.getElementById('show-button');var deviceID=document.getElementById('device-id');var connectForm=document.getElementById('connect-form');var public_key_callback={success:function(a){console.log('Public key: '+a.b);public_key=a.b;rsa.setPublic(public_key.substring(58,58+256),public_key.substring(318,318+6));},error:function(a,b){console.log(a);window.alert('There was a problem fetching important information from your device. Please verify your connection, then reload this page.');}};var device_id_callback={success:function(a){var b=a.id;deviceID.value=b;},error:function(a,b){console.log(a);var c='COMMUNICATION_ERROR';deviceID.value=c;}};var scan=function(){console.log('Scanning...!');disableButtons();scanButton.innerHTML='Scanning...';connectButton.innerHTML='Connect';document.getElementById('connect-div').style.display='none';document.getElementById('networks-div').style.display='none';getRequest(base_url+'scan-ap',scan_callback);};var scan_callback={success:function(a){network_list=a.scans;console.log('I found:');var b=document.getElementById('networks-div');b.innerHTML='';if(network_list.length>0)for(var c=0;c<network_list.length;c++){ssid=network_list[c].ssid;console.log(network_list[c]);add_wifi_option(b,ssid);document.getElementById('connect-div').style.display='block';}else b.innerHTML='<p class=\\'scanning-error\\'>No networks found.</p>';},error:function(a){console.log('Scanning error:'+a);document.getElementById('networks-div').innerHTML='<p class=\\'scanning-error\\'>Scanning error.</p>';},regardless:function(){scanButton.innerHTML='Re-Scan';enableButtons();document.getElementById('networks-div').style.display='block';}};var configure=function(a){a.preventDefault();var b=get_selected_network();var c=document.getElementById('password').value;if(!b){window.alert('Please select a network!');return false;}var d={idx:0,ssid:b.ssid,pwd:rsa.encrypt(c),sec:b.sec,ch:b.ch};connectButton.innerHTML='Sending credentials...';disableButtons();console.log('Sending credentials: '+JSON.stringify(d));postRequest(base_url+'configure-ap',d,configure_callback);};var configure_callback={success:function(a){console.log('Credentials received.');connectButton.innerHTML='Credentials received...';postRequest(base_url+'connect-ap',{idx:0},connect_callback);},error:function(a,b){console.log('Configure error: '+a);window.alert('The configuration command failed, check that you are still well connected to the device\\'s WiFi hotspot and retry.');connectButton.innerHTML='Retry';enableButtons();}};var connect_callback={success:function(a){console.log('Attempting to connect to the cloud.');connectButton.innerHTML='Attempting to connect...';window.alert('Your device should now start flashing green and attempt to connect to the cloud. This usually takes about 20 seconds, after which it will begin slowly blinking cyan. \\n\\n\\nIf this process fails because you entered the wrong password, the device will flash green indefinitely. In this case, hold the setup button for 6 seconds until the device starts blinking blue again. Then reconnect to the WiFi hotspot it generates and reload this page to try again.');},error:function(a,b){console.log('Connect error: '+a);window.alert('The connect command failed, check that you are still well connected to the device\\'s WiFi hotspot and retry.');connectButton.innerHTML='Retry';enableButtons();}};var disableButtons=function(){connectButton.disabled=true;scanButton.disabled=true;};var enableButtons=function(){connectButton.disabled=false;scanButton.disabled=false;};var add_wifi_option=function(a,b){var c=document.createElement('INPUT');c.type='radio';c.value=b;c.id=b;c.name='ssid';c.className='radio';var d=document.createElement('DIV');d.className='radio-div';d.appendChild(c);var e=document.createElement('label');e.htmlFor=b;e.innerHTML=b;d.appendChild(e);a.appendChild(d);};var get_selected_network=function(){for(var a=0;a<network_list.length;a++){ssid=network_list[a].ssid;if(document.getElementById(ssid).checked)return network_list[a];}};var copy=function(){window.prompt('Copy to clipboard: Ctrl + C, Enter',deviceID.value);};var toggleShow=function(){var a=document.getElementById('password');inputType=a.type;if(inputType==='password'){showButton.innerHTML='Hide';a.type='text';}else{showButton.innerHTML='Show';a.type='password';}};var getRequest=function(a,b){var c=new XMLHttpRequest();c.open('GET',a,true);c.timeout=8000;c.send();c.onreadystatechange=function(){if(c.readyState==4)if(b){if(c.status==200){if(b.success)b.success(JSON.parse(c.responseText));}else if(b.error)b.error(c.status,c.responseText);if(b.regardless)b.regardless();}};};var postRequest=function(a,b,c){var d=JSON.stringify(b);var e=new XMLHttpRequest();e.open('POST',a,true);e.timeout=4000;e.setRequestHeader('Content-Type','multipart/form-data');e.send(d);e.onreadystatechange=function(){if(e.readyState==4)if(c){if(e.status==200){if(c.success)c.success(JSON.parse(e.responseText));}else if(c.error)c.error(e.status,e.responseText);if(c.regardless)c.regardless();}};};if(scanButton.addEventListener){copyButton.addEventListener('click',copy);showButton.addEventListener('click',toggleShow);scanButton.addEventListener('click',scan);connectForm.addEventListener('submit',configure);}else if(scanButton.attachEvent){copyButton.attachEvent('onclick',copy);showButton.attachEvent('onclick',toggleShow);scanButton.attachEvent('onclick',scan);connectForm.attachEvent('onsubmit',configure);}getRequest(base_url+'device-id',device_id_callback);getRequest(base_url+'public-key',public_key_callback);";
const char prng4_js[] = "function Arcfour(){this.i=0;this.j=0;this.S=new Array();}function ARC4init(a){var b,c,d;for(b=0;b<256;++b)this.S[b]=b;c=0;for(b=0;b<256;++b){c=(c+this.S[b]+a[b%a.length])&255;d=this.S[b];this.S[b]=this.S[c];this.S[c]=d;}this.i=0;this.j=0;}function ARC4next(){var a;this.i=(this.i+1)&255;this.j=(this.j+this.S[this.i])&255;a=this.S[this.i];this.S[this.i]=this.S[this.j];this.S[this.j]=a;return this.S[(a+this.S[this.i])&255];}Arcfour.prototype.init=ARC4init;Arcfour.prototype.next=ARC4next;function prng_newstate(){return new Arcfour();}var rng_psize=256;";
Page myPages[] = {
     { "/index.html", "text/html", index_html },
     { "/rsa-utils/rsa.js", "application/javascript", rsa_js },
     { "/style.css", "text/css", style_css },
     { "/rsa-utils/rng.js", "application/javascript", rng_js },
     { "/rsa-utils/jsbn_2.js", "application/javascript", jsbn_2_js },
     { "/rsa-utils/jsbn_1.js", "application/javascript", jsbn_1_js },
     { "/script.js", "application/javascript", script_js },
     { "/rsa-utils/prng4.js", "application/javascript", prng4_js },
     { nullptr }
void myPage(const char* url, ResponseCallback* cb, void* cbArg, Reader* body, Writer* result, void* reserved)
    Serial.printlnf("handling page %s", url);
    if (strcmp(url,"/index")==0) {
        Serial.println("sending redirect");
        Header h("Location: /index.html\r\n");
        cb(cbArg, 0, 301, "text/plain", &h);
        return;
    int8_t idx = 0;
    for (;;idx++) {
        Page& p = myPages[idx];
        if (!p.url) {
            idx = -1;
            break;
        else if (strcmp(url, p.url)==0) {
            break;
    if (idx==-1) {
        cb(cbArg, 0, 404, nullptr, nullptr);
    else {
        cb(cbArg, 0, 200, myPages[idx].mime_type, nullptr);
        result->write(myPages[idx].data);
void myHandler(const char *event, const char *data)
  if (strcmp(data,"open")==0) {
    digitalWrite(button,HIGH);
    delay(2000);
    digitalWrite(button,LOW);
    STARTUP(softap_set_application_page_handler(myPage, nullptr));
    pinMode(button,OUTPUT);
    Particle.subscribe("jacksonministorpb", myHandler);
void loop(){
  if (digitalRead(button)==HIGH) {
        Particle.publish("jacksonministor","open");
As far as the code you may want to add a delay to the loop. I believe that particle will only take 1 publish per second (it may take a burst of 4, but then you have to wait until 4 second are up before it will take more).
Someone else will have to help get it to flash for you. Still learning…
Considering it still has no credentials, that seems like expected behavior, don't you think? Try placing it in Listening mode while it's doing that and give setup another shot.
This is not how you’d use the STARTUP() macro. This line should go after your two include lines.
Do add a way to rate-limit your publishes as @carbuthn has suggested.
Can you not set the credentials via the SoftAP page you have set up in your application?
Since you have CLI, have you tried providing the credentials via particle serial wifi plus manuale entry (no autoscan!)?
You can also try the serial terminal way via the command w
Won’t be leaving work for awhile so I’m installing the particle toolchain on my work computer. I’ll let you guys know the progress as soon as I’m done.
So I reflashed my photon over serial, with the factory tinker app, it flashes magenta, then comes up flashing blue, If I try to connect to it over the app, the photon ID comes up and when I touch it it pops up “connecting to photon” but it flashes this message 5 times, with the “busy” circle going around, then comes up with:
“Error
Please try running setup again after resetting your Photon and putting it back in blinking blue listen mode if needed.”
If I try to setup wifi over my computer, I select the network name, then enter the password and it says success but I never get past a green flashing light.
While in DFU mode, try doing “particle update”, as well as “particle flash --usb tinker”, then, hold SETUP until the LED starts blinking blue rapidly, indicating the credentials have been erased. Once that’s done, give ‘particle serial wifi’ a shot, and enter the information manually.
Ok, so two of them I was able to recover using the instructions you gave @Moors7, the last one I brought home, not able to get into safe mode, in DFU mode, tried particle update, says successful, reboots and gives a hard fault with SOS, put back in DFU, tried particle flash --usb tinker, says successful, reboots and gives a hard fault with SOS. I found another discussion here: Photon in RED SOS hard fault mode, unable to put into safe mode. Looks like this one may be down for the count, unless a new development has come up since this post.
Have you got the most recent (currently 1.16.0) CLI installed?
Try (again)
particle update
To narrow down the root of your WiFi troubles, try flashing a simple sketch with SYSTEM_MODE(MANUAL) which lets you control each step of the connection process
WiFi.on()
WiFi.connect()
WiFi.ready()
Particle.connect()
Particle.connected()
Paricle.process()
And see where the process trips.
If you wish, you can also add
STARTUP(WiFi.selectAntenna(ANT_INTERNAL))
WiFi.useDynamicIP()
WiFi.clearCredentials()
WiFi.setCredentials()
@ScruffR, I’ll try this in about an hour when I get home, I did update the CLI, but I’m not sure what version it is, I’ll check this too. This is my personal photon so I hope I can recover it, I’ve got big plans! About the softap code on the board, I think I’ve either copied something wrong from the repo or the repo has some corruption in it, either way I’ve deleted all apps with that firmware and I’ll try later with it.
