Hello all,
I’m new here, so sorry if I’m posting in the wrong spot, etc…
I have a Photon setup taking distance measurements every 10 minutes, those are published and then I have a nodeJS script running as a daemon to get that data and insert it into a MySQL DB.
It’s all working fine, but for some reason the process just seems to fail after a few hours or so. I’m not really sure on the time period yet before it fails.
Here are my code samples:
Particle firmware:
// Trash Sensor
// Purpose: Using HC-SR04 sensor to collect distance data to determine if trash cans are full and need to be emptied
// Author: David Cool
// Version: 1.0
#include <HC-SR04.h>
STARTUP(System.enableFeature(FEATURE_RETAINED_MEMORY));
* define ranges for each can */
// unknow device "default"
int min0 = 10;
int max0 = 50;
// tashi-iot-1
int min1 = 10;
int max1 = 60;
// tashi-iot-2
int min2 = 10;
int max2 = 200;
// tashi-iot-3
int min3 = 5;
int max3 = 85;
The HC-SR04 device is a 5V device. So, VIN (which is 5V when connected to a USB power supply)
is used to power it. Also, the "Echo" pin will present a 5V pulse, which can be connected
to any of the D* GPIO pins, as they are 5V tolerant. However, they cannot be connected to
non-5V tolerant pins, like the A* pins, even if in digitial mode.
This example expects the wiring to be as follows:
Photon HC-SR04
GND GND
VIN VCC
A0 Trig
D0 Echo
// trigger / echo pins
const int triggerPin = A0;
const int echoPin = D0;
HC_SR04 rangefinder = HC_SR04(triggerPin, echoPin);
int data;
// used to store device name
char dev_name[32] = "";
bool publishName = false;
unsigned long firstAvailable = 0;
int counter;
retained int retainedCounter = 0;
void handler(const char *topic, const char *data) {
strncpy(dev_name, data, sizeof(dev_name)-1);
Serial.printlnf("received %s: %s", topic, dev_name);
publishName = true;
// start serial monitor
// setup the distance sensor
rangefinder.init();
// get device name from cloud
Particle.subscribe("particle/device/name", handler);
Particle.publish("particle/device/name"); // <-- ask the cloud for the name to be sent to you
bool wifiReady = WiFi.ready();
bool cloudReady = Particle.connected();
Serial.printlnf("wifi=%s cloud=%s counter=%d retainedCounter=%d", (wifiReady ? "on" : "off"), (cloudReady ? "on" : "off"),
counter++, retainedCounter++);
if (wifiReady) {
if (firstAvailable == 0) {
firstAvailable = millis();
if (millis() - firstAvailable > 20000) {
// After we've been up for 20 seconds, go to sleep. The delay is so the serial output gets written out before
// sleeping.
Serial.println("calling System.sleep(SLEEP_MODE_DEEP, 600)");
delay(2);
// SLEEP_MODE_DEEP timinig is in SECONDS, NOT microseconds!!!
System.sleep(SLEEP_MODE_DEEP, 600);
// The rest of the code here is not reached. SLEEP_MODE_DEEP causes the code execution to stop,
// and when wake up occurs, it's like a reset where you start again with setup(), all variables are
// cleared, etc.
Serial.println("returned from sleep, should not occur");
if (publishName) {
// Publish an event every ? minutes. The event is JSON formatted and has a
// value "distance" that updates each time.
// Process distance values based on specific trash can installations and which device is installed there
if (dev_name == "tashi-iot-1") {
// get current distance sensor reading in inches
data = rangefinder.distInch();
data = 100 - ( ((data - min1) * 100) / (max1 - min1) );
else if (dev_name == "tashi-iot-2") {
data = 100 - ( ((data - min2) * 100) / (max2 - min2) );
else if (dev_name == "tashi-iot-3") {
data = 100 - ( ((data - min3) * 100) / (max3 - min3) );
else {
data = 100 - ( ((data - min0) * 100) / (max0 - min0) );
char trash_data[64];
snprintf(trash_data, sizeof(trash_data), "{\"distance\":\"%d\",\"name\":\"%s\"}", data, dev_name);
Particle.publish("trash_data", trash_data, PRIVATE);
delay(1000); // to ensure adhering to rate limit
else {
firstAvailable = 0;
delay(1000);
nodeJS server:
var config = require('./config.json');
var Particle = require('particle-api-js');
var particle = new Particle();
var mysql = require('mysql');
// Make sure you update the required MySQL server settings in config.json!
var con = mysql.createConnection({
host:config.mysql_host,
user:config.mysql_user,
password:config.mysql_password,
database:config.mysql_database});
con.connect(function(err) {
if (err) throw err;
console.log("Connected to database");
// "sse-examples-01" in the Particle event to filter on. It's a prefix, so all events beginning with this
// name are stored in the database.
particle.getEventStream({ deviceId:config.deviceFilter, auth:config.authToken, name:'trash_data' }).then(
function(stream) {
stream.on('event', function(event) {
console.log("event: ", event);
// This assumes that the data in the event is valid JSON!
var data = JSON.parse(event.data);
// The "distance" value in the JSON is stored in the distance column in the SQL d$
// create table example02 (id INT NOT NULL AUTO_INCREMENT, device VARCHAR(34), ts$
var sql = "INSERT INTO trash_sensor (device, name, ts, distance) VALUES ('" + eve$
con.query(sql, function (err, result) {
if (err) throw err;
console.log("inserted: " + sql);
function(err) {
console.log("Failed to getEventStream: ", err);
The other bit of this is I’m using pm2 (http://pm2.keymetrics.io/) to daemon-ize the nodeJS script.
It’s all working great the first few? hours but then no data is inserted into the SQL DB. If I monitor the process with pm2 it shows it as up and running, and nothing sticks out in the logs. If I restart the process it works again as expected but then fails in a few hours again.
Is there anything that would time out, etc on the Particle side of things causing this problem?
I’m not sure how to track this down. Any ideas are most welcome!
Cheers
