(Photon ) Neopixel library not compiling locally with MAKE, PIN_MAP issue
I know this post is very similar to my problem;
When trying to compile an app with the neopixel library for photon locally i get an error, on the cloud I do not
Im getting error:
applications/Box5/Neopix.cpp:58:52: note: in expansion of macro 'pinLO'
 #define pinSet(_pin, _hilo) (_hilo ? pinHI(_pin) : pinLO(_pin))
applications/Box5/Neopix.cpp:238:9: note: in expansion of macro 'pinSet'
         pinSet(pin, HIGH); // HIGH
applications/Box5/Neopix.cpp:55:56: error: 'struct GPIO_TypeDef' has no member n
amed 'BSRRL'
   #define pinHI(_pin) (PIN_MAP2[_pin].gpio_peripheral->BSRRL = PIN_MAP2[_pin].g
pio_pin)
applications/Box5/Neopix.cpp:58:38: note: in expansion of macro 'pinHI'
applications/Box5/Neopix.cpp:241:11: note: in expansion of macro 'pinSet'
           pinSet(pin, LOW);
applications/Box5/Neopix.cpp:54:56: error: 'struct GPIO_TypeDef' has no member n
amed 'BSRRH'
   #define pinLO(_pin) (PIN_MAP2[_pin].gpio_peripheral->BSRRH = PIN_MAP2[_pin].g
pio_pin)
............. it goes on referring to the same issue
in Neopixel CPP:
#include "Neopix.h"
  #include "application.h"
  STM32_Pin_Info* PIN_MAP2 = HAL_Pin_Map(); // Pointer required for highest access speed
  #define pinLO(_pin) (PIN_MAP2[_pin].gpio_peripheral->BSRRH = PIN_MAP2[_pin].gpio_pin)
  #define pinHI(_pin) (PIN_MAP2[_pin].gpio_peripheral->BSRRL = PIN_MAP2[_pin].gpio_pin)
// fast pin access
the aforementioned posts make me think i need to replace the gpio.peripheral-->bSRRH line and th e one below it with some sort of fastread/fastwrite function ?
Thanks for the help,
Gary
@godjohnson, are you compiling with PLATFORM = photon? To be honest, those functions should be using the new pinSetFast() and pinResetFast() functions. I’ll ping @BDub to get his thoughts since he’s the library owner.
yes I am compiling with that line included, I wasnt sure why it compiles fine on WebIDE and particle dev but not locally. I saw in another post that you recommended replacing with those functions, but the register names did not have H and L at the end.
@godjohnson, the longer register names are used on the STM32F205 of the Photon vs the shorter names of the Core’s STM32F103. I’ll post a PR to the library but @BDub may not be able to do the merge until the Electron is released. Since you’ve copied the library files locally, the changes are simple:
#if PLATFORM_ID == 0 // Core
  #define pinLO(_pin) (PIN_MAP[_pin].gpio_peripheral->BRR = PIN_MAP[_pin].gpio_pin)
  #define pinHI(_pin) (PIN_MAP[_pin].gpio_peripheral->BSRR = PIN_MAP[_pin].gpio_pin)
#elif (PLATFORM_ID == 6) || (PLATFORM_ID == 8) || (PLATFORM_ID == 10) // Photon (6) or P1 (8) or Electron (10)
  #define pinLO(_pin)   pinResetFast(_pin)
  #define pinHI(_pin)   pinSetFast(_pin)
#else
  #error "*** PLATFORM_ID not supported by this library. PLATFORM should be Core, Photon, or P1 ***"
#endif
// fast pin access
#define pinSet(_pin, _hilo)   digitalWriteFast(_pin, _hilo)
ill give it a try thanks so much!
It’s compiling locally ok for me so I’m wondering what your full make command is, and what directory you are in? For me I’m using commands like this:
✶brett✶ ~/code/firmware/modules $ make clean all PLATFORM_ID=6 APPDIR=~/code/fw-apps/neo2 COMPILE_LTO=n -s
  /Users/brett/code/firmware/modules/photon/system-part1/makefile /Users/brett/code/firmware/modules/photon/system-part2/makefile /Users/brett/code/firmware/modules/photon/user-part/makefile
   text	   data	    bss	    dec	    hex	filename
 249704	    144	    132	 249980	  3d07c	../../../build/target/system-part1/platform-6-m/system-part1.elf
 169924	   2044	  38428	 210396	  335dc	../../../build/target/system-part2/platform-6-m/system-part2.elf
   7068	      8	    376	   7452	   1d1c	/Users/brett/code/fw-apps/neo2/target/neo2.elf
✶brett✶ ~/code/firmware/modules $ make clean all PLATFORM_ID=8 APPDIR=~/code/fw-apps/neo2 COMPILE_LTO=n -s
 249704	    144	    132	 249980	  3d07c	../../../build/target/system-part1/platform-8-m/system-part1.elf
 170420	   2132	  38496	 211048	  33868	../../../build/target/system-part2/platform-8-m/system-part2.elf
✶brett✶ ~/code/firmware/modules $ make clean all PLATFORM_ID=10 APPDIR=~/code/fw-apps/neo2 COMPILE_LTO=n -s
  /Users/brett/code/firmware/modules/electron/system-part1/makefile /Users/brett/code/firmware/modules/electron/system-part2/makefile /Users/brett/code/firmware/modules/electron/user-part/makefile
 122900	    192	    360	 123452	  1e23c	../../../build/target/system-part1/platform-10-m/system-part1.elf
 110312	   2668	   5128	 118108	  1cd5c	../../../build/target/system-part2/platform-10-m/system-part2.elf
   7164	      8	    452	   7624	   1dc8	/Users/brett/code/fw-apps/neo2/target/neo2.elf
You do have to edit the example file to include function prototypes for rainbow and Wheel and #include neopixel.h" instead of #include neopixel/neopixel.h" (I also edited this one to work with an older version of the Internet Button which uses A7 and 11 pixels)
 * This is a minimal example, see extra-examples.cpp for a version
 * with more explantory documentation, example routines, how to
 * hook up your pixels and all of the pixel types that are supported.
#include "neopixel.h"
SYSTEM_MODE(AUTOMATIC);
// IMPORTANT: Set pixel COUNT, PIN and TYPE
#define PIXEL_PIN A7
#define PIXEL_COUNT 11
#define PIXEL_TYPE WS2812B
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
void rainbow(uint8_t wait);
uint32_t Wheel(byte WheelPos);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  rainbow(20);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
   WheelPos -= 170;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
:white_check_mark: Also make sure you have a recent commit pulled from the firmware repo.
Hey sorry I started another semester of school and have been very busy. Im assuming my problem probably lies in incorrect use of Make GNU and firmware version issues, I will try and update you when I have more time to investigate, thanks for the response.
Gary
