Multiple definition of 'PIN_MAP' error with Photon
Hello folks,
When compiling a simple program using two libraries that utilize PIN_MAP, I’m getting the error below:
Both libraries have been adapted to work with the Photon, and they run well when used independently.
It seems that the root cause is this declaration STM32_Pin_Info* PIN_MAP = HAL_Pin_Map();
What is the best practice? Should I rename PIN_MAP once per library: PIN_MAP_LIB1, PIN_MAP_LIB2, etc…?
Change the definition to
static STM32_Pin_Info* PIN_MAP = HAL_Pin_Map();
So that it becomes a non-exported symbol.
(I had meant to mention this in the PIN_MAP thread, but got sidetracked by other discussions.)
Thank you @mdma!
That worked well.
