Photon is unable to connect to wifi after flashing static IP code. [ SOLVED ]
It was very short burst of orange.
Thank you, Sir. Thank you very much.
You have helped me within a couple of hours to solve the problem which I have been struggling for 8 hours.
It worked like a charm.
I was looking through this thread.
I typed these in terminal provided in the above thread.
  1. particle keys server cloud_public.der
  2. particle keys new photon
  3. particle keys load photon.der
  4. particle keys send photon.pub.pem
No 4. command did not work in Terminal.
At the moment, I saw your reply.
Then I typed in command you provided.
< particle keys doctor myDeviceID >
Magically, I see cyan breathing on photon.
Photon is connected to wifi and my web server works like it did before.
Again, thank you very much, Sir.
It means a lot to me.
