Can't get Photon to connect to cloud using static ip
I am trying to use a static IP address on a Photon but I keep getting dns errors when it tries to connect to the cloud. Without static it works fine although I have had to go through setup to get it to connect to the cloud again.
Below is the output of photon.bin with and the without static IP. I reserved the static address for the photon with the Midco app. I have the internal and external port assignments set to 5683. Not sure if they should be set in this manner. I believe my credentials are set correctly. As you can see in the logs below I can't even ping the dns server or the google dns server when using static. Does anyone have any suggestions?
Thank you,
Bob
***** When running Photon.bin without Static IP *******
Serial connection closed. Attempting to reconnect...
Serial monitor opened successfully:
configured credentials:
ssid=Brz73FfZ security=wpa2 cipher=1
available access points:
SSID=Brz73FfZ security=wpa2 channel=6 rssi=-33
SSID=Willie J security=wpa2 channel=6 rssi=-65
SSID= security=wpa2 channel=6 rssi=-66
SSID=CarlofNYC security=wpa2 channel=6 rssi=-58
SSID=G&G security=wpa2 channel=6 rssi=-61
SSID=Versteeg security=wpa2 channel=6 rssi=-73
connecting to WiFi
connected to WiFi!
localIP=192.168.0.119
subnetMask=255.255.255.0
gatewayIP=192.168.0.1
dnsServerIP=192.168.0.1 (often 0.0.0.0)
dhcpServerIP=192.168.0.1 (often 0.0.0.0)
ping gateway=1
ping dnsServerIP=1
ping addr 8.8.8.8=1
device.spark.io=34.199.82.114
0000012922 [wiring] TRACE: TCPClient socket=200076b8
connected to device server CoAP (testing connection only)
connecting to cloud
0000012974 [system] INFO: Cloud: connecting
0000013056 [system] INFO: Cloud socket connected
0000013057 [comm.protocol.handshake] INFO: Establish secure connection
0000013641 [comm.protocol.handshake] INFO: Sending HELLO message
0000013641 [comm.protocol.handshake] INFO: Receiving HELLO response
0000013642 [comm.protocol] INFO: waiting 4 seconds for message type=0
0000013688 [comm.protocol] TRACE: rcv'd message type=0
0000013688 [comm.protocol.handshake] INFO: Handshake completed
0000013710 [comm.protocol] INFO: Sending subscriptions
0000013713 [system] INFO: Cloud connected
connected to the cloud!
*** Running Photon.bin with Static IP ****
SSID=2wire 2020 security=wpa2 channel=1 rssi=-70
SSID=Brz73FfZ security=wpa2 channel=6 rssi=-30
SSID=Willie J security=wpa2 channel=6 rssi=-62
SSID=CarlofNYC security=wpa2 channel=6 rssi=-57
SSID=NETGEAR81 security=wpa2 channel=5 rssi=-72
SSID=Nila residence security=wpa2 channel=1 rssi=-73
connecting to WiFi
connected to WiFi!
localIP=192.168.1.119
dhcpServerIP=0.0.0.0 (often 0.0.0.0)
ping gateway=0
ping dnsServerIP=0
ping addr 8.8.8.8=0
failed to get device.spark.io from DNS, try 1
failed to get device.spark.io from DNS, try 2
failed to get device.spark.io from DNS, try 3
device.spark.io=0.0.0.0
connecting to cloud
0000036743 [system] INFO: Cloud: connecting
0000051754 [system] WARN: Cloud socket connection failed: -230
0000056754 [system] WARN: Internet test failed: DNS
0000056754 [system] WARN: Handling cloud error: 2
0000056754 [system] INFO: Cloud: connecting
0000071765 [system] WARN: Cloud socket connection failed: -230
0000076765 [system] WARN: Internet test failed: DNS
0000076765 [system] WARN: Handling cloud error: 2
Your combination of static local IP, subnet mask, and gateway are not valid. The gateway must be within your subnet.
Typically with an address of 192.168.1.119 and a subnet mask of 255.255.255.0 your gateway would be 192.168.1.1, not 192.168.0.1.
Or you have a subnet mask of 255.255.127.0, with 9 bits of host which would have the localIP and gateway in the same subnet.
Hello Rick,
Thank you for reply. I somehow put 192.168.1.119 in my code instead of 192.168.0.119, the addy of the static ip I had reserved in the router. Major brain flatulence... After two days of banging my head you saved me from two more of the same.
Thank you, Bob
